New Trailer Hitch
New Trailer Hitch
Postby droid_ca » Sun Jan 27, 2013 3:05 am
http://shockerhitches.ca/
There is a guy in my town selling these and I was wondering :thinking: if anybody new anything about them Good :thumbsup: or Bad :thumbdown: They are around $500.00 bucks... :thinking: Thanks for any input
“Fide Canem”
viewtopic.php?f=5&t=52816
droid_ca
Images: 176
Re: New Trailer Hitch
Postby Lgboro » Sun Jan 27, 2013 9:37 am
That would weigh more that my tear and equipment I haul for and extended trip. Maybe if I wanted to take my house.........
Lgboro
Images: 53
Postby Martiangod » Sun Jan 27, 2013 9:42 am
In priciple looks good. Fifth wheel air rides do cushion, but they can be aired up and just checked once in awhile. This needs to be aired down each time you slide it into the receiver, then aired up. Sounds like a royal pain, will have to have a compressor on hand all the time.
In many jurasdictions its illeagle to have a hitch on if your not towing at the time. So for longer stayd when you want to tool around town on your vacation, you will need a compressor at your site to hook up to head home.
Me for one don't like driving with air ride hitches or multi pivot fifth wheels because of all the extra action going on back there
Chris
Deep in the Heart of Nowhere
Martiangod
Images: 432
Postby droid_ca » Sun Jan 27, 2013 10:44 am
I was thinking for in regards to my Tiny House project, as the weight will be a little higher..but there would be a compressor....and taking it off and on would be a bit of a Pain in the
“Fide Canem”
droid_ca
Images: 176
Postby Dale M. » Mon Jan 28, 2013 9:14 am
Looks like a expensive solution to a non existent problem... OR I do not understand what it does......
Dale
Dale M.
Images: 18
Postby pete42 » Mon Jan 28, 2013 11:37 am
interesting idea and I can see how this may dampen the up and down movement on a larger trailer
I used equlizer hitch when I was towing my travel trailer I really didn't feel it going up and down
maybe a good equalizing hitch would work for you and I'm sure it would be cheaper.
pete42
Postby droid_ca » Mon Jan 28, 2013 12:33 pm
I'm thinking that my tiny house will have some substantial weight behind it so I'd like to consider all of my best options to prevent a catastrophy from happening, I'd also like to be able to use my half ton to pull it so there might be a few mods that may be needed to be done to my tow vehicle as well
“Fide Canem”
droid_ca
Images: 176
Postby Dale M. » Tue Jan 29, 2013 9:53 am
I pull a tandem axle car carrier that weighs in at 1470 lbs and some times have it loafed with a race car (1360 lbs) and sometime with what ever car I have to move (any car or truck or tractor) my experience has always been if you get load balanced properly (tongue weight) trailer and car behave properly..... Only issues I have is when loads start getting heavy is BRAKES NEED TO BE WORKING PROPERLY..... And yes I tow with 2005 Chevy Silverado pickup....
If it were me I would get trailer hooked up with properly balanced load (tongue weight) and take it for a cruise before investing another $500 in to something that may not be needed.....
Dale
Dale M.
Images: 18
Postby Martiangod » Tue Jan 29, 2013 10:11 am
That WILL NOT increase load capabilities, Only cushion the connection. If weight is a problem then load distributing hitch is what you will need.
Air bags on truck may help but are not always the answer.
I have Bags on my ranger, but I much prefer to distribute the weight with an equalizing hitch with a travel trailer on. Distyributing hitch is also a safer option then air as it puts some of the trailer weight up on your stearing axel making a safer driving total package. I have air to lessen the longterm fatigue on my springs from carrying tools all the time, not for carrying excessive loads
Chris
Martiangod
Images: 432
Postby droid_ca » Tue Jan 29, 2013 6:45 pm
I'm just trying to think of ways to stay safe on the highways
“Fide Canem”
droid_ca
Images: 176
Postby Engineer Guy » Tue Jan 29, 2013 7:10 pm
The big problem is loss of control as the Tongue weight causes the rear Axle of the TV to become the pivot point, as in a Children's See Saw on a Playground. There's nothing about the item you're looking at that would help prevent this potentially-dangerous bit of 'Physics 101' from playing out as you tow a heavy load.
Read here how Equalizer Bars actually shift Tongue weight to both TV Axles, nipping this problem in the bud.
Equalizer Hitch Tutorial
~Reality proceeds with or without your consensus~
Engineer Guy
Images: 118
Postby Bogo » Tue Jan 29, 2013 9:29 pm
I can see where this may be good if you have a trailer with a flexible frame. The 5th wheel flatbed we have was made a bit light so it suffers from surge when going over bumps. A thing I'll note about it is I see the air bag, but where is the damping in the system. It is adding a suspension point, and in this case it is an air spring with no damping. Damping is needed to keep oscillation down.
Bogo
Images: 39
Postby droid_ca » Tue Jan 29, 2013 9:55 pm
I'm wanting to use this with a tiny house so not sure about the flexing but I highly doubt there will be any
“Fide Canem”
droid_ca
Images: 176
Postby Dale M. » Wed Jan 30, 2013 10:40 am
droid_ca wrote:I'm wanting to use this with a tiny house so not sure about the flexing but I highly doubt there will be any
Just how big is your "tiny house" and what makes you think you need a extra $500 investment into something that may not be needed..... I still say its somebody solution to non-existent problem....
Dale
Dale M.
Images: 18
Postby droid_ca » Wed Jan 30, 2013 3:24 pm
The frame that I have is 20 feet and I would like to extend it another 6 feet
“Fide Canem”
droid_ca
Images: 176
