Styrofoam and polystyrene
Postby Javier_Pacer » Thu Jan 31, 2013 7:44 pm
I saw blue Styrofoam 1/2 inch r value 3.
Polystyrene white stuff with foil backing 1 inch 2.85 R value.
Which has better integrity and how much is insulation overkill when doubling insulation does not give much R value?
Thanks
Javier_Pacer
Re: Styrofoam and polystyrene
Postby Javier_Pacer » Thu Jan 31, 2013 8:47 pm
This would go into a CT cavity to 1 3/4 .
Javier_Pacer
Postby Javier_Pacer » Thu Jan 31, 2013 8:55 pm
Thanks
Javier_Pacer
Postby Javier_Pacer » Thu Jan 31, 2013 9:33 pm
:lol:
Javier_Pacer
Postby Lgboro » Thu Jan 31, 2013 10:33 pm
I planed my blue insulation to 3/4" and glued up two pieces to fill my 1 1/2" walls. It is very, very quiet inside and heats and cools very easily. Well worth the effort and expense in my opinion.
Lgboro
Images: 53
Postby Bogo » Mon Feb 04, 2013 6:00 pm
Javier_Pacer wrote:I saw blue Styrofoam 1/2 inch r value 3.
Thanks
If you want the foil layer, it needs a tiny bit of air space to work. For one project I used 1/8" beads of construction adhesive every 6" in a diamond pattern to hold the foam in place, and keep it slightly away from the surface it was glued to. That gave the foil face a small area to reflect across. Also, most foams are a moisture barrier form the standpoint of a house so the foil being a moisture barrier isn't an issue. You can get foil faced craft paper if the foam you choose doesn't have a foil face and you want one.
Bogo
Images: 39
