Simple Maryland 5 wide build
Postby JTROBB » Sat Feb 02, 2013 7:13 pm
I have a good start and have 2 complete walls. Need to connect them with roof bows and the floor.
101562101619101620101621101851101852101853101854101855
JTROBB
Images: 132
Re: Simple Maryland 5 wide build
Postby RandyG » Sat Feb 02, 2013 7:20 pm
That's a solid start, good luck!
Randy
RandyG
Images: 115
Postby Junkboy999 » Sat Feb 02, 2013 8:04 pm
I’ll Second that motion.
Great start. Keep the picture coming.
Junkboy999
Images: 52
Postby JTROBB » Sun Feb 03, 2013 5:44 pm
I obtained a cheap trailer yesterday, it is a 5x8 jiffy trailer with 13 inch tires. started pulling the side off that the previous owner had made. I also made a jig and screwed the 2 sides with roof bows and floor joists. Is there any thing I need to check to make sure it is square before i glue it? All I have done so far to check square is a corner to corner measure.
Jason
101907101906101905101904101903101902101901
JTROBB
Images: 132
Postby ST1100 » Sun Feb 03, 2013 5:58 pm
Do you have a hitch at your Super7 ?
50 years camper and 35 years biker !
1977 Eriba Troll
2001 Honda GL1800 with trailer hitch, Ford Focus Pininfarina Convertible with hitch
ST1100
Images: 199
Postby JTROBB » Sun Feb 03, 2013 6:20 pm
No hitch, actually sold the locost 7 to move on to the next project. But the project I'm most proud of is the locost, 2 years and from scratch.
Jason
JTROBB
Images: 132
Postby JTROBB » Mon Feb 04, 2013 7:10 pm
Glued the framing up tonight, looks the same so no new pics. Next step cutting and sliding the floor into the dado.
Jason
JTROBB
Images: 132
Postby JTROBB » Tue Feb 05, 2013 5:50 pm
Installed the floor today.
101952101951101950
JTROBB
Images: 132
Postby absolutsnwbrdr » Tue Feb 05, 2013 8:04 pm
Nice progress! If you keep up the pace, you'll have it done in time to join a bunch of us for a gathering March 15-17, about an hour north of you in Street, Maryland. Theres going to be about 10-15 trailers, a BBQ cookoff, and a ton of fun! All the info is over on the Tearjerkers forum, under the Chesapeake Chapter. Even if you don't have it done, bring a tent or just stop out for the day :thumbsup:
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Postby JTROBB » Wed Feb 06, 2013 6:51 pm
I don't think it will be done by then. I plan to fiberglass the exterior with a single layer of glass and there is a good chance the temperature will not cooperate. I may stop in for the day though just to check the tears out.
No new pics today, just trimmed the plywood for the interior roof to size and started cutting the inner roof bows.
Jason
JTROBB
Images: 132
Postby JTROBB » Fri Feb 08, 2013 7:51 pm
Got the first inside sheet for the ceiling installed and glued and the second sheet in place but not glued yet.
Jason
102006102005102004
JTROBB
Images: 132
Postby JTROBB » Sat Feb 09, 2013 1:33 pm
Installed the shelf and finished the interior roof today
Jason
102020102019102018102017102016102015
JTROBB
Images: 132
Postby JTROBB » Sun Feb 10, 2013 6:42 pm
Started to add the roof insulation today. Got through the better part of 2 sheets of insulation before I realized I could score and cut it like drywall.
Jason
102065
JTROBB
Images: 132
Postby JTROBB » Mon Feb 11, 2013 6:30 pm
No new pics tonight. Finished fitting foam for the roof and kerfed the hard angles. Epoxied the end grain on all the ply and was unable to open garage to take pics, trying to keep the heat in the garage so that the epoxy hardens.
Jason
JTROBB
Images: 132
Postby JTROBB » Tue Feb 12, 2013 6:17 pm
Got a good start on the roof. still lots of drilling and screwing to go. Then time to pull it all off and glue it.
Jason
102128102127102126
JTROBB
Images: 132
