Lgboro wrote:Why not build it a permanent box similar to a tongue box so you don't have to set it up each time? Probably wouldn't be any heavier than a small slide out that requires set up each time and easier to weather seal.
Woodbutcher wrote:Can you hinge a fold down door for the extention? Then sew a tent for cover. Some of the new trailers are using them. Similar to a pop up only the door would fold down. You could also do it in reverse with the extra foot area on a pull out and the door opens upward with the tent attached.
S. Heisley wrote:Lgboro wrote:Why not build it a permanent box similar to a tongue box so you don't have to set it up each time? Probably wouldn't be any heavier than a small slide out that requires set up each time and easier to weather seal.
That's a good idea. Somebody did that not too long ago; but, I can't remember who or where the thread is.... It all depends on what works best for your build.
