What size sq tubing is typ. used for a 2" receiver hitc
Postby BoilermakerFan » Wed Sep 29, 2004 8:17 am
Starting the serious design or modifcations of a 2+2 TD based on Andrew's design. I want to add a 2" receiver at the rear for a Canoe rack of bicycle rack. What size tubing do I need to accept the retail racks made by Yakima?
Brian
BoilermakerFan
Postby bg » Wed Sep 29, 2004 9:04 am
Vehicle end is 2.5"x2.5"x0.25" Square tubing
Attachment is 2"x2"x0.25" square tubing
Bobby(, Kim & Wayne)
bg
Postby mexican tear » Wed Sep 29, 2004 9:11 am
The easiest thing to do is go to any auto parts store and buy a receiver hitch. The bumper mounted one welded upside down on the back of the frame (a little support if necessary) works great. You then have the extra support ring in the front and the pin hole in the correct place.
I bought mine at Tractor supply.
here is a pic of mine from e-trailer
http://www.etrailerpart.com/receivertubes.htm
kai
"Essie" and the Mexican Tear
mexican tear
Images: 14
Postby BoilermakerFan » Wed Sep 29, 2004 9:39 am
Thanks Kai, That would be the easiest way since I would be laying out a custom frame anyway!
BoilermakerFan
Postby McTeardrops » Wed Sep 29, 2004 6:13 pm
Brian
A word of caution on the 2 1/2" tubing. Most tube is welded, the weld bead running full length along one side. I bought a stick, thinking I could grind the weld and make my own receiver tube... WRONG. I'll make you a real good deal if you want to try yourself!
Lenny
[email protected]
I've reached the stage, in life, where my foam has more memory than I do!
McTeardrops
Postby BoilermakerFan » Wed Sep 29, 2004 6:51 pm
Thanks Lenny. I'm not going to make my own, but that's one additional reason why I shouldn't. I'm just going to follow Kai recommendation and either buy the receiver tube or a universal hitch.
BoilermakerFan
Postby Steve Frederick » Thu Sep 30, 2004 8:31 am
The reciever that I welded on my tear was $10 at the local farm supply store
Blessings, Steve
Adirondacks, Upstate New York
Building Journals
Steve Frederick
Custom Teardrop Builder
Images: 29
