Fishingtomatoseed wrote: How would you be able to find a crack in a spring? Magnet and metal dust? Just the sound of it when it rings?
I read through the leaf spring rebuild in this section. I believe I will be doing that to this trailer before another trip.
doug hodder wrote:Old springs can potentially always be an issue. Who knows just how they've been treated all their lives? Even if not cracked...they may have been overloaded at some point and weakened. If it's not something unusual...why not just get a new pair from the get go? That way, at least you know what you have to begin with. The time and money spent on the side of the road clowning around with a broken spring if you can't limp home far outweighs the price of a new pair. God forbid if you have to have it towed. Just my opinion, but new springs are cheap insurance. doug
I am going to order new springs and then do the " up grade " to them that is a sticky on this page.
48Rob wrote:I am going to order new springs and then do the " up grade " to them that is a sticky on this page.
It is important, and easy to do now, since you are replacing the springs, to order the new set to be matched to your trailers actual weight.
Many home made camping trailers are much lighter than the load the springs were originally intended to carry as a cargo trailer.
Figuring your actual fully loaded weight, and adding 500 pounds or a little more, will give you a ride, and handling that rival that of a luxury car.
Rob
