Should I or shouldnt I
Postby Vindi_andy » Wed Feb 20, 2013 7:41 am
I have the opportunity to get a pair of rear wheel arches as fitted on to tango for £120
The wife isnt sure but I thought Id ask you guys.
The rear wings stop where the black piping is. Your thoughts please.
Boys never grow in to men the toys just get more expensive and more dangerous
How true :)
Vindi_andy
Images: 49
Re: Should I or shouldnt I
Postby Woodbutcher » Wed Feb 20, 2013 8:51 am
If you can afford them and they would work, I say "Why Not" . My only concern would be, can you fill the wheel well with the trailer tire? That looks like a pretty beefy size tire and the fender will look silly if it is not the right scale.
Woodbutcher
Postby Mitchelkitman » Wed Feb 20, 2013 8:59 am
You could narrow them if needed so the tyres look ok - however that may be a lot of work/detract from the 'bargain' price if you have to do a lot of work. If you need to narrow them could you take a partial splash off yours, or speak with the manufacturer who may have some damaged parts or produce a partial part for you for a better price?
Mitchelkitman
Postby Vindi_andy » Wed Feb 20, 2013 11:07 am
The tyres on tango are 195/45/15 and the chassis is running standard caravan wheels rather than trailer wheels not sure of the size but they arent tiny ones.
How true :)
Vindi_andy
Images: 49
Postby S. Heisley » Wed Feb 20, 2013 6:19 pm
I think they'd look nice! :yes:
Postby Corwin C » Wed Feb 20, 2013 10:10 pm
My first thought is to wonder what they would look like switched so they are backwards on the tear from the car. From what I can see, it would accentuate your tear's profile more closely. Are the tail lights in the fender? I looked, but couldn't find a view of the back of your TV in your galley.
If you have matching fenders, you'll want to make sure that you can get rims and tires that match to complete the illusion. It may end up costing quite a bit more than just the cost of the fenders.
Corwin
Image Image Image
-- myself
Corwin C
Images: 78
Postby Vindi_andy » Thu Feb 21, 2013 7:32 am
I wanted to get matching wheels unfortunately this particular style is now obsolete so will have to either get some clearance ones or second hand.
Yes the lights are mounted in the Wheel arches (fenders) Photo below. They were expensive too as they are LED mix and match ones. Not sure we would comply with the lighting regs in UK if we put the lights in the fenders in terms of visibilty angles as the fenders sit well forward of the back of the rear of the tear.
The upper set is the stop tail with indicator inner and the lower ones are reverse inner with reflector outer and fog light inner on the other side.
How true :)
Vindi_andy
Images: 49
Postby Corwin C » Thu Feb 21, 2013 10:11 pm
It's entirely up to you, just throwing out ideas. If it was mine, I would consider running that fender "backwards" possibly with the lights "frenched" into the tapered side of the fender, or even moving the lights to the hatch and leaving the fender pristine. Now that I look at the back, the fender may be a little more angular than I originally thought and it may not compliment your teardrop profile as much as I originally thought. It may work, it may not ... again, it's all up to you.
Corwin
Image Image Image
-- myself
Corwin C
Images: 78
Users browsing this forum: rmclarke and 16 guests
