Source for clips to wall-mount my Maglight?
Postby Oregon Brew » Wed Feb 27, 2013 12:17 am
Hi -
Building a trailer for my daughter for her wedding present. I'd like to be able to clip a big Maglight flashlight to the wall right next to the door. Anyone have a source for such clips (if they exist) or have any clever ideas?
Oregon Brew
Re: Source for clips to wall-mount my Maglight?
Postby NEINCAMPER » Wed Feb 27, 2013 4:52 am
If you are thinking of the 4 D cell rechargable maglight they come with a very nice charging base that can be mounted to the wall. If you were looking for something else other than the large maglight, I would suggest the smaller streamlight rechargable LED that is also able to be mounted with a supplied base. Just a side note the good thing about the larger maglight is the secondary use as a handy little bat if the need arises.
NEINCAMPER
Postby ParTaxer » Wed Feb 27, 2013 9:05 am
What about broom handle clips. Would that be too small for a Maglite? They can be stretched somewhat.
Mike
I have wisdom beyond my years. In fact, I'm nearly senile.
ParTaxer
Images: 32
Postby Dale M. » Wed Feb 27, 2013 10:25 am
Hardware store that carry MAG lights usually have them....
https://www.google.com/search?hl=en&saf ... miaHYmo6ok
I have them in my Jeep, and Chevy pickup and wife's car..... Keeps flashlight right were I want it....
Dale
Dale M.
Images: 18
Postby GuitarPhotog » Wed Feb 27, 2013 2:20 pm
Dale, those are for the mini-maglight. I have looked and have not found a similar product for my 4-D cell "cop style" Maglite.
<Chas>
GuitarPhotog
Images: 55
Postby Jacquie » Wed Feb 27, 2013 4:52 pm
Oregon Brew,
What a wonderful wedding gift! My daughters are 15 and 10, so that will buy us some time...
http://www.opticsplanet.com/streamlight ... 27215047:s
That link may have what you need. Not sure if it's for the mini or the large one.
Jacquie
Postby Moon » Wed Feb 27, 2013 6:34 pm
Here's one that claims to be for the D cell. - http://www.amazon.com/gp/aw/d/B00002N9ER
Or you might be able to mod the belt loop holder? - http://www.amazon.com/gp/aw/d/B000056BMW
Moon
Postby Oregon Brew » Wed Feb 27, 2013 8:40 pm
Thanks everyone! I thought my local hardware store might have one, but no luck. I finally checked ebay early this morning and found some before I read your responses. Since I have to buy the flashlight yet anyway, I might buy the one with the recharger and save the clips for me! Thanks again!
Bob
Oregon Brew
Postby Dale M. » Wed Feb 27, 2013 9:30 pm
GuitarPhotog wrote:Dale, those are for the mini-maglight. I have looked and have not found a similar product for my 4-D cell "cop style" Maglite.
<Chas>
Go directly to jail, do not pass go, do not collect $200...
Umm.... Text on card (in red stripe) state "D" cell.....
Link is to pretty much GENERIC sources.....
UPDATE... Was poking around in local hardware store and the have MAGLITE brand clips in AA, C & D sizes....
Dale
Dale M.
Images: 18
Postby GuitarPhotog » Wed Feb 27, 2013 11:56 pm
<Chas>
Dale
Mea culpa. Missed the fine print.
<Chas>
:beer:
GuitarPhotog
Images: 55
Postby txcamper » Fri Mar 01, 2013 3:20 pm
I use the quick fist mounts in my truck for D mag lights, shovel, etc.
They've been opened and closed a lot and are holding up well.
http://www.quickfistclamps.com/
Here's some install information (not mine or my truck, just useful)
http://www.expeditionportal.com/resourc ... lamps.html
txcamper
Images: 129
Postby Gladtobehere » Fri Mar 01, 2013 6:17 pm
You could just use any tube mounted vertically as a simple holder for a maglite. ABS plastic comes to mind. The plus side is no pointy bits to hook a sleeve on.
Gladtobehere
Postby RandyG » Fri Mar 01, 2013 6:36 pm
I would use a hinge with a piece of... whatever you prefer, aluminum, wood, plastic. Cut your piece of material into a ring and attach your hinge then attach the other side of the hinge to the wall. When the Maglite is not in the ring it will fold down. You would be less likely to bump into it and break it or yourself. Just like the mop and broom holder stated above.
Randy
RandyG
Images: 115
Postby stanimal » Fri Mar 01, 2013 10:21 pm
Quadratec has something that may work.
http://www.quadratec.com/products/15179_201X_PG.htm
I have one of these for my jeep. Hold the mag light secure, and is good quality.
stanimal
Postby tamnalan » Fri Mar 01, 2013 10:28 pm
Oww!
You could buy two D cell maglite flashlights for the cost of a single bracket!
tamnalan
