My build of Benroy Style Trailer
Re: My build of Tiny Trailer
Postby KCStudly » Wed Feb 27, 2013 5:27 pm
Nice. :thumbsup:
Postby AlgoDan » Wed Feb 27, 2013 5:33 pm
Thanks KC
KCStudly wrote:Nice. :thumbsup:
Here now but Camping later.............Dan
Build Journal
http://www.tnttt.com/viewtopic.php?f=50&t=54681
102535 103199 105576
From .................Paper...........................To.......................... Pavement............................
AlgoDan
Images: 238
Postby mallymal » Wed Feb 27, 2013 6:08 pm
That's a lovely elegant simple profile. Good work :thumbsup:
mallymal
Images: 18
Postby Oldragbaggers » Wed Feb 27, 2013 6:40 pm
RandyG wrote:Great start! I like your floor dolly, I may have to use the idea so I can easily move out to the driveway and back to the garage at night.
Randy, we got our dolly from Harbor Freight. They had them on sale for $59 and I had a 20% off coupon to boot. It would have been worth every penny if I had paid double. I have to move my trailer in and out of the garage to work on it, and the farther along the build gets, the heavier the trailer gets. Plus we use it to move our utility trailer around the yard. I would highly recommend making the investment.
Life is sooooo good.........
Sail...camp....bike...repeat
Becky
Oldragbaggers
Images: 331
Postby AlgoDan » Wed Feb 27, 2013 7:10 pm
Thanks, simple works for me.....
mallymal wrote:That's a lovely elegant simple profile. Good work :thumbsup:
Build Journal
AlgoDan
Images: 238
Postby AlgoDan » Wed Feb 27, 2013 7:27 pm
More pics
Layout of cabinet pattern
102634
Treat all edges with CPES prior to priming
102633
Roof framing all done
102632
Inside view
102631
Aluminum skin is in
102627
Pattern layout
102628
Aluminum skin cut
102629
Test fit window and door
102630
Build Journal
AlgoDan
Images: 238
Postby RandyG » Wed Feb 27, 2013 8:08 pm
Be aware of fatigue with the aluminum.
Shadow Catcher wrote:You might want to consider 5086 or 6061 marine grade. The problem I ran into is the finite modulus of elasticity of aluminum. There was a lot of flex/bounce at the point where the frame 2X4X.25 rectangle went under the body of the trailer. This is where #1 MM failed, Both sides snapped. These are pictures of the original construction minus the additional bracing.
58160
58163
You might want to check on what is used for horse trailers, not much that is more corrosive on aluminum than horse pee. Boat trailers are also made using aluminum.
You're tongue isn't as long as his was and your A-frame goes under the floor frame so it shouldn't be a issue. You also have more welding surface area. Are you the one welding it?
I hope Shadowcatcher doesn't mind me sharing his post but thought I should spread his lessons learned.
Randy
RandyG
Images: 115
Postby AlgoDan » Wed Feb 27, 2013 8:33 pm
Thanks Randy, yes aware of aluminum fatigue.This is my second Aluminum trailer I have built and use 6061 .
RandyG wrote:Be aware of fatigue with the aluminum.
58160
58163
Build Journal
AlgoDan
Images: 238
Postby AlgoDan » Wed Feb 27, 2013 9:25 pm
A timelapse of mock up of build
102965
Build Journal
AlgoDan
Images: 238
Postby AlgoDan » Thu Feb 28, 2013 7:45 pm
More pictures
102680
Ceiling light and fan
102681
Cupboard doors/handles
102683
110V Outlet and Access door
102684
110V Inlet and Shower
102687
End profile
102682
Brake light
102691
Galley hatch build
102688
Galley latch
102690
Galley floor/wall trim
102689
Galley
102685
Insulation begins
102686
Insulated
Build Journal
AlgoDan
Images: 238
Postby AlgoDan » Sat Mar 02, 2013 11:52 am
A couple of pics, starting on suspension...3500lb axle w/1250 springs. With custom mounting brackets for attaching to aluminum frame. The brackets will get powder coating.
102760
102759
102761
Build Journal
AlgoDan
Images: 238
Postby AlgoDan » Sat Mar 02, 2013 3:02 pm
Ok got 5 sheets of .125 Luan for skinning hatch and roof
Skinning the roof
102764
Skinning the Galley Hatch
102763
Build Journal
AlgoDan
Images: 238
Postby KCStudly » Sat Mar 02, 2013 7:40 pm
You're going to be done and camping before you know it. Good work! :thumbsup:
Postby AlgoDan » Sat Mar 02, 2013 8:41 pm
Thanks working on it, should be out for first camp end of April....
KCStudly wrote:You're going to be done and camping before you know it. Good work! :thumbsup:
Build Journal
AlgoDan
Images: 238
Re: My build of Benroy Style Trailer
Postby AlgoDan » Mon Mar 04, 2013 3:20 pm
Ok got all Luan cut to fit on the roof..
102886
102885
102887
Next step go over all the wiring in the roof to see if ready, then glue and screw...
Build Journal
AlgoDan
Images: 238
