Self healing trailers , whooda’ thunk it ???
Steaming like that is for wood which will react with the moisture in the steam and expand. The foam won't react to the moisture.atahoekid wrote:Just a thought foe dent removal. If you laid a wet towel over the dents and then heated the towel with a heat gun would it steam enough? Would that steam raise the dimples? Just thinking out loud...
