Ok got my Galley latch mounting plate cut and fitted for the latches..next I will start the hinge and strut mounting....
KCStudly wrote:Is that two slam latches set into a trim plate?
I don't think I have seen that before, but it should work okay, yeah?
Junkboy999 wrote:Look really good
I take it the aluminum around the galley hatch and the side wall are two different pieces?
I’m curious on how the back edge and the sides meet and gets sealed.
Do you have a metal break? Those folds looks great.
91kuhndog wrote:Nice build Dan... I think I'm going to go with that square back design as well. My original plans were going to use the Benroy sloped galley but from what I can see, I'd be giving up a lot of space in the galley. That's awesome though.
AlgoDan wrote:Test mounting jig
Ok today I was testing Hatch strut location mounting and load ratings. Hatch weighs 24lbs. At first mount on hatch at 7'' Hatch weighs 46lbs.with 2-30lb struts door will stay up but light to the touch. Will likely exchange for 2-50lb struts...trial and error, always learning....will post what works the best. In the photo I set up a mounting jig half ass with the hatch, as not to drill to many locating holes in the trailer. The hatch will get skinned with aluminum when location is bang on....
KCStudly wrote:Cruising right along! Keep on keeping on!
