Hello knowledgeable teardrop enthusiasts!
I have introduced us here.
This thread will be our build journal.
nevadatear wrote:Welcome aaron and tess! That beautiful tear was built by our friend joe kosoreff of vacations in a can. If you two come down to the dam gathering the first f may, you can most likley can see it in person. You dont have to have a trailer to attend nd it is a grwtbopportunit to see probaby over a hundred all inone place!
NebraskaTeachr wrote:I really like your profile. Have you seen the design library by AngiB?
txcamper wrote:Have you decided on width yet? Are you sticking with the 4' wide? I only ask because the extra 1' of a 5' wide makes a big difference...
_Ryan_ wrote:Looks good! May I suggest that instead of cutting the frame down and worrying about axle placement and balancing, you just make the trailer a bit longer to fully cover the original frame. Yes this would involve splicing a bit of plywood, but it should be no harder than cutting down the trailer, and besides you will have a bit more room when planning your galley.
