Whatcha do on your build today?
Re: Whatcha do on your build today?
Postby Vedette » Wed Mar 13, 2013 11:12 am
Wel I finally got off the couch last night and got back to work on Miss Piggy! :applause:
Felt great! :thumbsup:
Got some final wiring for storage area lihgts, and air conditioning blower wired up.
Just small things, they keptme busy until 2:00 am. :shock:
Good Roads
Brian
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Postby AlgoDan » Wed Mar 13, 2013 2:55 pm
I went to get my sealant for the aluminum skin, and finishing up on the Galley hatch.
Here now but Camping later.............Dan
Build Journal
http://www.tnttt.com/viewtopic.php?f=50&t=54681
102535 103199 105576
From .................Paper...........................To.......................... Pavement............................
AlgoDan
Images: 238
Postby AlgoDan » Wed Mar 13, 2013 3:46 pm
I bought some DAP Premium Polyurethane Sealant...Window/Door sealant from Home Depot...seems to be what I need.. :thumbsup:
biziedizie wrote:AlgoDan, what sealant did you end up using?
Build Journal
AlgoDan
Images: 238
Postby len19070 » Wed Mar 13, 2013 4:53 pm
Took mine out for the first time on its "Shake Down Cruise"........... 30 some miles, 70 mph, No Problems.
viewtopic.php?f=50&t=54252
Happy Trails
Len
len19070
Images: 24
Postby AlgoDan » Wed Mar 13, 2013 5:06 pm
Lucky you, looking good and ready for the season..... :thumbsup:
len19070 wrote:Took mine out for the first time on its "Shake Down Cruise"........... 30 some miles, 70 mph, No Problems.
Happy Trails
Len
Build Journal
AlgoDan
Images: 238
Postby TESKELLY » Wed Mar 13, 2013 8:15 pm
Installed a much needed rain guard over the rear doors.
TESKELLY
Images: 19
Postby len19070 » Thu Mar 14, 2013 4:18 am
slowcowboy wrote:whats the vent in back by the door. is that a aircontdioner or a rv furnace?
slow
Its an AC.
Happy Trails
Len
len19070
Images: 24
Postby TESKELLY » Thu Mar 14, 2013 3:26 pm
TESKELLY
Images: 19
Postby len19070 » Thu Mar 14, 2013 3:56 pm
TESKELLY wrote:Stabilizers installed :)
Those are nice :thumbsup:
I thought I would need rear stabilizers at the rear of mine. When I built the frame and tried to sit in the back to see how the dropped floor would work the darn thing did a "Wheelie".
But then after I got it built there was so much weight in the forward area I didn't have to worry.
The thing that really put it over the top was the battery as far forward as possible.
Now I do realize that these 2 trailers have 2 different purposes in mind.
Happy Trails
Len
len19070
Images: 24
Postby TESKELLY » Thu Mar 14, 2013 6:32 pm
biziedizie wrote:Looking good Kelly :) Are those adjustable an removable? I can't expand the pics in photobucket :(
They are removable via bolt and wing nut. I lower the front crank down then remove and drop the rear stabilizers to the lower set of bolt holes then crank up the front again until it is level and sitting on the legs. This does unfortunately require a semi level camping spot but I can adjust somewhat with the front crank to compensate for unevenness or might add additional holes to pick from in the back..
TESKELLY
Images: 19
Postby Wolffarmer » Thu Mar 14, 2013 9:52 pm
Slow, no work on mine either. Long day hauling cow crap also. But that is what I do most days. I drive a manure truck, an ex over the road with a lengthened frame and manure box on it. WE beat the crap out of those trucks. They just where not meant to be used on farms and such. And I probably shift it more in one day than an OTR driver does in 2 weeks of driving.
Slow probably already knows what we do to those trucks, I kind of threw this in for those that are not ag based.
8) Randy
Wolffarmer
Images: 309
Postby Vedette » Thu Mar 14, 2013 10:13 pm
Go easy Steve
Remember....Big Brother is watching. :thinking:
did you get anything done today? Idid again 3rd day in a row! :applause:
Brian
Good Roads
Brian & Sandi
Vedette
Images: 443
Postby pchast » Fri Mar 15, 2013 2:28 pm
It just keeps getting longer...
pchast
Images: 97
Postby Shadow Catcher » Fri Mar 15, 2013 3:38 pm
Picked up an adapter for the gray water tank outlet. I do not like the twist lock RV connectors on the stinky slinky so switched to a 3" cam-lock. For Canada we will not be moving the trailer for 8 days and this way the gray water can be dumped into a 5 gal flex water tank and dumped. I now had a 3" to 3/4 water hose adapter. A couple of days back I picked up the Progressive Industries EMS to hard wire in.
Postby Vedette » Sun Mar 17, 2013 1:34 am
My short list is getting very short. :applause:
Had a large number of distractions today........Good day for me......bad day for Miss Piggy!
But now retirement is one step closer.
Good Roads
Brian & Sandi
Good Roads
Brian & Sandi
Vedette
Images: 443
