Managed to get the converter and fuse block in tonight.
Overall should be ok for what I need. Well the light worked anyway. Batteries are ready to go in, should be here by early next week.
Found a nifty little fuse block that worked out great and should be fine with solar down the road.
Solar is something I need help with (lots and lots of help) Think I am at the right place..
Have decided to leave the nose alone for now, will get the refrig. and mount it in its limited space and decide how I want to handle everything else. With the boss ladies potty things are really getting tight in that V, not a lot a room for storage. I think my best bet is to just get it functional and decide after a few camping trips. Kind of think about things a little more.
Anyway, in my tracking down the electric, I solved a problem with the rear ramp, seems 2 of the 3 screws holding a trim piece on are keeping the door from sealing. When it gets a bit warmer out I will replace them with rivets. Would have been a lot easier at the factory as they took the time to notch out a bit of the ramp flap to gain some clearance. I guess you get what you pay for in labor. Simple fix anyway, at least I don't have to cut the hinges off and reweld as that is what I origianally thought I would end up doing.
