Portable ac questions
Re: Portable ac questions
Postby Myates » Tue Mar 19, 2013 8:34 am
The bed is already built and installed. It's actually not a true king. 6' long by 5'11 wide. This will give us plenty of room for our two year old to sleep with us as well.
Road inspector how do you plan on sealing up the whole when not in use??
22 Because of the Lord’s great love we are not consumed,
for his compassions never fail.
23 They are new every morning;
great is your faithfulness.
Myates
Postby b.bodemer » Tue Mar 19, 2013 9:04 am
You could add a cargo door to use with your window ac.
http://cttraveltrailer.blogspot.com/201 ... alled.html
Barb
b.bodemer
Images: 328
Postby Myates » Tue Mar 19, 2013 11:13 am
Hey barb. Now that is a clean installation. Did you install the cargo door?
Myates
Postby b.bodemer » Tue Mar 19, 2013 2:24 pm
The cargo door was installed at the factory. Here's another look at the set up from outside:
http://cttraveltrailer.blogspot.com/201 ... mised.html
I knew my house ac worked nice with the window units so I had the factory install the cargo door at a counter height. Works great. When it's not needed(spring and fall) I store the ac in my garage. Also allows for a screen insert for some extra fresh air when the ac is not needed.
Barb
b.bodemer
Images: 328
Postby roadinspector » Tue Mar 19, 2013 9:55 pm
Myates wrote:The bed is already built and installed. It's actually not a true king. 6' long by 5'11 wide. This will give us plenty of room for our two year old to sleep with us as well.
Like the others said. I will install a cargo door. It will act as a rain cover when in use & is oversized to accommodate any size I want to put in. A waterproofed plywood frame will be built to fill up the void. Thats my plan any way. Others have had good success with this. If it ain't broke, don't fix it.
:relaxing:
Earnest
Dadgum it! I cut that board 5 times and it's still too short!
2001 quad-cab Dodge Cummins 3/4 ton camper special, 16x7x7 CT work in progress toyhauler, 01 HD Ultra Classic, 98 HD Heritage Softail, 88 HD 1200 Sportster. viewtopic.php?f=42&t=51510
roadinspector
Images: 127
