Plastic hatch hinge questions
Re: Plastic hatch hinge questions
Postby GaryDierking » Sat Jun 23, 2012 12:06 am
pohukai wrote:I really like the design of the EURO/New Zealand plastic hinge, but I can't seem to locate a supplier here in the US. Anyone know of one? The only ones I have found look like a flat strap; which will work but I'd prefer non-aluminum with a profile like those pictured here in this thread.
Jim
Here's the description of the hinge: http://www.retwine.co.nz/products/545/1 ... 04&cid=545
I got it from a company that sells parts for large trucks.
Gary
http://teardropbygary.blogspot.co.nz/
GaryDierking
Images: 10
Postby Craig Burrowes » Mon Jul 09, 2012 4:36 am
I have used this hinge on a luggage trailer and it has held up well over the last 6 years, but the weight of the two doors is minimal. Your hatch will be be reasonably heavy so if you go ahead make sure you install it in such a way that you can remove it again if it splits.
Craig Burrowes
Images: 54
Postby GaryDierking » Wed Jul 11, 2012 12:50 am
I had to buy a 3 Meter piece so I have enough for a replacement. I would have preferred an all external hinge but could not find anything like that in NZ.
Craig Burrowes wrote:I have used this hinge on a luggage trailer and it has held up well over the last 6 years, but the weight of the two doors is minimal. Your hatch will be be reasonably heavy so if you go ahead make sure you install it in such a way that you can remove it again if it splits.
GaryDierking
Images: 10
Postby MeelisV » Sat Jul 28, 2012 2:55 pm
same plastic hinge used on door
A woman has the last word in any argument.
Anything a man says after that is the beginning of a new argument.
MeelisV
Images: 105
Postby jimun » Sun Mar 23, 2014 11:58 pm
I came across this hinge when I googled teardrop hinges and seen it on GaryDierking td. Has anyone else used this hinge and are there any updates on how they are working? I found a supplier that stocks it in the USA and I am thinking of using it on my td build for the hatch and doors like on MeelisV td.
Benroy Style 5x10 Build - http://www.tnttt.com/viewtopic.php?f=50&t=57462
Now to Him who is able to do far more
abundantly beyond all that we ask or think,
according to the power that works within us,
Eph 3:20 (NASB)
jimun
Images: 10
Postby WhitneyK » Mon Mar 24, 2014 8:00 am
:thumbsup: Yep, still holding up after 2 years and 7000 miles :thumbsup:
Are they sturdy enough? My hatch is soooooo heavy (that's another subject I'll be approaching soon). It is 60 lbs to lift from the handle, approx 175-200 lbs where the props are and that's a lot of pressure on the hinge area. :shock:
Whitney & Tracie
Crothersville, IN
We never really grow up, we only learn how to act in public.
Do not confuse what you hear with what I mean.
My build: http://www.tnttt.com/viewtopic.php?t=41955
160061-------------------------------101114
States we've drug our
li'l camper through. (44 States + Vancouver Island and over 45,000 miles so far)
WhitneyK
Images: 412
Postby Steve_Cox » Tue Apr 01, 2014 9:53 am
jimun wrote:I came across this hinge when I googled teardrop hinges and seen it on GaryDierking td. Has anyone else used this hinge and are there any updates on how they are working? I found a supplier that stocks it in the USA and I am thinking of using it on my td build for the hatch and doors like on MeelisV td.
Hatch hinge, 9 years old and still working. Harsh Environment Continuous plastic hinge.
http://www.mcmaster.com/#continuous-hinges/=rcj5ji
Steve_Cox
Images: 196
Postby grantstew8 » Tue Apr 01, 2014 4:19 pm
My plastic hinge is similar to those posted. It's barely used as I'm still building.
If your are in the uk google Albert jaeger they supply truck and bus builders. I'm guessing if it works in that environment it will work on my td hatch. It's called a continuous hinge. Besides being easy to fit its waterproof. :)
grantstew8
Images: 77
Postby grantstew8 » Tue Apr 01, 2014 4:23 pm
I remembered I have a video
[youtube]q-zRtXs5mvo[\youtube]
http://youtu.be/q-zRtXs5mvo
grantstew8
Images: 77
Postby jimun » Tue Apr 01, 2014 6:46 pm
grantstew8 wrote:My plastic hinge is similar to those posted. It's barely used as I'm still building.
Thanks grantstew8, I am in the USA and I did find a supplier here in the states and I already placed my order for 2 - 8'+ (2.5m) plastic continuous hinges. 1 for the hatch and 1 for the doors. Thanks for the youtube video, That helps on how I am going to install it on mine.
For anyone that is interested in these hinges you can get them at Moore Industrial Hardware in Cincinnati, Ohio. You can order on there website http://www.mooreindhardware.com/index.html. I got both hinges for about $90.00 including shipping. They have 2 sizes, 1 is just about 1" (23mm) deep and the other is just about 1 3/8" (34mm). I am trying the smaller one. I did not check the depth when I order, I just thought the design was a little different. If I would have notice the depth I might of went with the deeper one. Image
Eph 3:20 (NASB)
jimun
Images: 10
Postby italianub » Thu Jan 25, 2024 11:23 pm
I have been searching for someone to ship me this hinge in the US for the last 2 months and I cannot believe I stumbled upon this post! I called mooreindhardware and hoping they call me back in the morning that they have the centaflex hinge. Thank YOU!
Build began Feb 10th, 2024
Build journal: viewtopic.php?f=50&t=76227
Video build journal: https://www.youtube.com/playlist?list=P ... 0ZP7TwtcT3
italianub
Postby italianub » Fri Jan 26, 2024 11:44 am
Update - they still have them! Call 800-543-1677, Hal helped me out from MRO hardware, they call it Plastic Continuous Hinge, in AU they call it Centaflex
Here's the link to the hinge (part number 4561-2231-125):
https://mrohardware.com/product/2-5m-4- ... ous-hinge/
The reason I want this hinge is because I am doing a squaredrop and I think this hinge will be perfect for helping me seal the rear hatch. I am basically following this video in regards to installation:
https://www.youtube.com/watch?v=JSTaxhU ... illedBeans
Cost was $48! I got a much longer piece than I'll need in case I want to use this for the side doors as well.
italianub
Postby italianub » Tue Jan 30, 2024 11:12 am
italianub wrote:Cost was $48!
The shipping was quite high, so in total it cost me about $133
italianub
Postby tony.latham » Tue Jan 30, 2024 11:15 am
I had one on my tongue box. It lasted three years. I bought it from McMaster Carr. It was marketed as, "UV resistant."
I hope it works for you.
Postby WhitneyK » Tue Jan 30, 2024 11:18 am
Just an update on my plastic hinge install.
I ended up replacing it with an aluminum hurricane hinge from Vintage Technologies.
The plastic one just didn't hold up well to the weight of my hatch, (60#) which I have since lightened a bit.
It was a thought, didn't say it was a good one...
Whitney
Whitney & Tracie
Crothersville, IN
WhitneyK
Images: 412
Users browsing this forum: Google [Bot] and 4 guests
