angib wrote:It might be worth asking if a bent laminated frame is necessary?
It appears to me that some teardrop builders think they are building a house where a self-supporting framework is built first and then skinned in with plywood to keep the weather out.
In a teardrop, the plywood does all the supporting and the framework is just there to hold the plywood flat and to make it easy to join the corners. If a framework is built first, and can hold itself up, then it's way overbuilt.
Andrew
RogHodge wrote:Your answer is no you do not need to bend/laminate the frame. The plans you are looking at, which I love BTW, also call for a canvas roof- I don’t think you will want to have one of those either.
