Unnamed offroad build - updated July 18 2010
Postby StormRider » Sat May 15, 2010 8:42 pm
I wanted an easy to build trailer to pull behind my jeep offroad, and finally decided to start building. I started with the look from the weekender and played with it until it started to look like a grasshopper :)
I wanted the same track width as the jeep to make it easy to tow offroad, and a queen size bed. I also wanted a common tire size with the jeep- 35x12.5 r15. I also wanted an entrance at the foot of the bed so I wasn't constantly dragging dirt/mud/sand across my head.
<img src="http://hphotos-snc3.fbcdn.net/hs358.snc3/29513_1365097661413_1650789676_863167_8282475_n.jpg"/>
Build Journal
StormRider
Materal costs
Postby StormRider » Sat May 15, 2010 8:45 pm
4x 10' 3"x2"x.120 steel tube - $120 Wasatch steel
3500lbs trailer axle, 10" brakes, 5 on 4.5 pattern - $340 state trailer
2x 3"x6"x.625 steel plate for recovery tabs - $18 metal supermarkets
2 used 15x10 black steel wheels: $50 classifieds
2 used Jeep CJ front Leaf springs, shackles, and shackle hangers: $40 Keep it Jeep
CJ bushings: $20 Amazon
6" x .25 x 4' steel plate - $20 metal supermarkets remnants
12" hitch receiver tube: $29 state trailer
Axle u-bolt kit: $19 state trailer
Build Journal
StormRider
Frame work
Postby StormRider » Sat May 15, 2010 8:52 pm
Frame tacked together:
and ready for the welding inspector:
3"x6"x.625 recovery tabs cut, drilled, and ready for welding:
Picked up the 3500lbs rated axle. 62" wide, 10" brakes, 5 on 4.5 bolt pattern:
Build Journal
StormRider
Postby doug hodder » Sat May 15, 2010 9:11 pm
Congrats on the start! It's so nice to work on new clean iron...what springs are you going to put under it? Doug
Postby greekspeedoman » Sun May 16, 2010 10:25 am
Storm.
I like the design. As another Jeep/teardrop person, I look forward to watching your build grow. Great photos. love the one of the Kiddo with the welding glasses! ha ha :applause:
greekspeedoman
Postby Rigsby » Sun May 16, 2010 4:37 pm
Great going, and in my opinion a proppa frame, non of this mecanno bolt together stuff
DOOIN IT THE YAARKSHA WAY--FA NOWT, THA NUS !!
Rigsby
May 16th update
Postby StormRider » Sun May 16, 2010 5:32 pm
welded the recovery tabs on:
I'm starting with 2000lbs trailer leaf springs. Eventually I'll replace the leafs with a 4 link airbag setup, but that's more fab work than I want to do this spring.
Build Journal
StormRider
Postby StormRider » Sun May 16, 2010 9:14 pm
Updated the sketchup model on the tongue so I can cut the arms and plates:
Build Journal
StormRider
Busy weekend may 23
Postby StormRider » Sun May 23, 2010 9:37 pm
Busy weekend-
Picked up most of the suspension pieces from Keep it Jeep, a Jeep salvage operation in SLC. Got Jeep CJ front leaf springs, shackles, and shackle hangers for $40. Ordered Poly bushings from Amazon for the springs, so I'll be ready to install the springs and axle later this week.
Metal Supermarkets has a great remnant section, and I picked up a piece of 6" x .25 x 4' plate for $20.
Also got a 12" receiver tube and u-bolt kit from state trailer supply.
Tacked and welded the A arms on:
Cut the receiver tube support plates:
Build Journal
StormRider
Postby StormRider » Mon May 24, 2010 9:51 pm
more welding done tonight-
Added .25 plate to the top and bottom of the receiver so it's 3" tall, matching the tongue arms, and cut to length:
And ready to be aligned and welded to the bottom plate:
Build Journal
StormRider
Postby StormRider » Mon Jul 19, 2010 6:19 pm
More progress than pics:
Got the floor put together, interior wheel wells done, axle tacked onto the frame, and some walls up :)
Build Journal
StormRider
