Painting aluminum cargo trailer roof for heat protection
Postby steveaus » Sat Jun 26, 2010 9:07 am
I've got a white cargo trailer that gets quite hot inside in the desert sun. I realized the roof is bare, unpainted aluminum.
Any suggestions on what I should use to paint it white? Just plain-old white paint?
Any idea why the factory leaves the roof unpainted?
steveaus
Re: Painting aluminum cargo trailer roof for heat protection
Postby madjack » Sat Jun 26, 2010 12:53 pm
steveaus wrote:I've got a white cargo trailer that gets quite hot inside in the desert sun. I realized the roof is bare, unpainted aluminum.
I would look for one of the insulating elastometric coating designed for mobile homes.....
errrr, because they can and it's cheaper that way................
Postby Shadow Catcher » Sat Jun 26, 2010 3:05 pm
Or polish/clean it up. There some insulative paints but not likely to do much unless you want to use something like http://www.thermoshieldproducts.com
Experience http://caravanersforum.com/viewtopic.php?f=2&t=6544 looks to be about $65 a gallon
Postby michiganflipper » Sun Jun 27, 2010 9:44 am
here is what i used on my trailer and it seem to make a big differnt http://www.koolseal.com/
michiganflipper
Postby astrotrailer » Sun Jun 27, 2010 11:50 am
I have 2 inches of insulation under the roof and it makes a big difference on keeping it cool.
astrotrailer
Postby steveaus » Tue Jun 29, 2010 4:16 pm
Thanks for the suggestions.
I've taken a look at some of those links. I guess the main question is will the elastomeric roof coatings significantly outperform a heavy coat of white high gloss paint?
I can see they are better for leaks, but I don't see whether or not they are much better than high gloss paint when it comes to reducing heat collection/transfer into the trailer.
steveaus
Postby steveaus » Wed Jun 30, 2010 9:17 am
michiganflipper wrote:here is what i used on my trailer and it seem to make a big differnt http://www.koolseal.com/
I looked at the Kool Seal. What did you do for prep below the Kool Seal. One coat or two of the Kool Seal?
Thanks!
steveaus
Postby razorback » Wed Jun 30, 2010 10:40 pm
read about this stuff. Quite expensive but the results seem to speak for themselves.
http://www.youtube.com/watch?v=xo0C4tOOT2A
There are many other links to this product.
good luck
larry
razorback
Postby michiganflipper » Sat Jul 03, 2010 4:46 pm
here is what i use it is from Bio kleen http://www.biokleen.com/aluminum-cleaner
michiganflipper
roof
Postby Jeffmo63 » Mon Jul 05, 2010 1:26 pm
I am going to try Rustoleum Marine White. It is relatvely inexpensive and I got it right off the shelf at Menards. See my album for pic of 140 degree roof temp. Also, per the recommendation of several I am installing a Fantastic vent. A little pricey but I am assured they are worth the money. Good luck.
Jeffmo63
Images: 81
Re: roof
Postby steveaus » Mon Jul 05, 2010 7:14 pm
Jeffmo63 wrote:I am going to try Rustolem Marine White. It is relatvely inexpensive and I got it right off the shelf at Menards. See my album for pic of 140 degree roof temp. Also, per the recommendation of several I am installing a Fantastic vent. A little pricey but I am assured they are worth the money. Good luck.
That's an impressive photo! Have you taken a measurement in comparable conditions with the Rustoleum Marine White?
steveaus
Re: roof
Postby Jeffmo63 » Mon Jul 05, 2010 7:29 pm
No, I have not made comparisons yet as I have not painted the roof. I am waiting for my Fantastic Vent to come in and I will install and paint roof at the same time.
Jeffmo63
Images: 81
Postby kennyrayandersen » Mon Jul 05, 2010 8:44 pm
I’m just curious, but it seems like I remember that aluminum might need some special prep work, no? Do keep us posted on the process, and the results (long and short term).
kennyrayandersen
Images: 38
Postby Jeffmo63 » Mon Jul 05, 2010 10:17 pm
kennyrayandersen wrote:I’m just curious, but it seems like I remember that aluminum might need some special prep work, no? Do keep us posted on the process, and the results (long and short term).
Yes, I think you are right about the aluminum. But I am nearly certain my trailer top is sheet steel like the sides. I had planned on washing it down really well with soap and water, rinsed, and followed with a scuffing with one of those green weenies (3M Scotchbrite pad). A wipe with mineral spirits just before painting ought to do it.
Jeffmo63
Images: 81
Postby kennyrayandersen » Mon Jul 05, 2010 11:17 pm
Jeffmo63 wrote:Yes, I think you are right about the aluminum. But I am nearly certain my trailer top is sheet steel like the sides. I had planned on washing it down really well with soap and water, rinsed, and followed with a scuffing with one of those green weenies (3M Scotchbrite pad). A wipe with mineral spirits just before painting ought to do it.
Somehow I was thinking it was aluminum -- so many of them I see are -- sounds like that should work OK
OH, I just realized Steve was saying HIS was aluminum -- I knew I had read that somewhere.
kennyrayandersen
Images: 38
