Is canvassing around things such as windows and doors just a matter of cutting out the right shape?
I just glued the canvas onto the side of the tear, got it all stuck, then used a razor blade to cut a slit up the middle of the door, then a slit running out to each corner, then I glued the canvas back into the recess the door sits into (rounding off the edge with a router helps the fabric glue in around a corner) I only trimmed it off flush at the inside edge of the inner ring. (my doors sit flush with an inner ring for it to seal against) this looks nicer IMO, and is important for keeping the bottom of the recess sealed against water.be_a_jayhawk wrote:Is canvassing around things such as windows and doors just a matter of cutting out the right shape?
Danidog wrote:
Does the canvas/glue stop checking in plywood or does it just cover it up?
