Hot Rod...Burning down the house!!!
Postby WhitneyK » Fri Feb 03, 2012 9:22 am
Martiangod wrote:SCORE !!!
Fantastic Fan for $50 and a 2 hour drive
Dealer take off from a new unit
Great Deal!!!
Movin' along quite nicely, were ya gettin' all the snow at? :snowstorm:
I haven't seen but a dusting or 2 of snow so far this winter, can't make any extra coins at 60F in February.?!
Keep up the good work! :thumbsup:
Whitney & Tracie
Crothersville, IN
We never really grow up, we only learn how to act in public.
Do not confuse what you hear with what I mean.
My build: http://www.tnttt.com/viewtopic.php?t=41955
160061-------------------------------101114
States we've drug our
li'l camper through. (44 States + Vancouver Island and over 45,000 miles so far)
WhitneyK
Images: 412
Postby aggie79 » Fri Feb 03, 2012 11:40 am
MG -
The cabinets are looking fantastic! Great find on the vent fan.
You're braver than I working inside the house. I ran out of storage space in the garage, so I thought I'd use a spare bedroom for cabinet storage until I could get them finished. You should have seen the look I got when I brought the first cabinet into the house.
Anyway...try to stay warm and keep up the good work.
Take care,
Postby bobhenry » Fri Feb 03, 2012 12:21 pm
I bolted together my first H.F. frame in the dining room with hardly a glance.
But God help me if I try and assemble anything on the kitchen counter top.
Images: 2614
Postby Martiangod » Fri Feb 03, 2012 12:39 pm
bobhenry wrote:But God help me if I try and assemble anything on the kitchen counter top.
Thats cause the kitchen counter is for your wash cans and parts soaking while you rebuild your carberator on the kitchen table :lol:
Oh, and been there, done that :roll:
Chris
Deep in the Heart of Nowhere
Martiangod
Images: 432
Postby bobhenry » Fri Feb 03, 2012 1:01 pm
God ! I gotta laugh at that one. :lol: :lol:
That brings back some old memories of decades ago.
( when carburators were simple enough that you could rebuild them ) :oops:
Images: 2614
Postby WhitneyK » Fri Feb 03, 2012 4:27 pm
What do you mean "I can't bring my motorcycle into the livin' room for the winter?" :noyes:
I got in trouble for trackin' stuff in from the garage on my shoes, let alone tryin' to bring any big pieces in. :BE
I still see little aluminum bits layin' here and there from time to time. :scratchthinking:
Whitney & Tracie
Crothersville, IN
WhitneyK
Images: 412
Postby Martiangod » Fri Feb 03, 2012 7:31 pm
WhitneyK wrote:What do you mean "I can't bring my motorcycle into the livin' room for the winter?" :noyes:
Now who went and told ya that, of course ya can
Chris
Martiangod
Images: 432
Postby Martiangod » Fri Feb 03, 2012 7:41 pm
Well the weathergods have been with me on this one.
Got a bit done today and yesterday.
Got the rear overhang dressed with some leftover roof and aluminum trim and it was above freezing so I got it caulked also
The floor extends past the back wall and has caused me some grief with snow sitting on it and melting....hence a bit of soak through. So dressed it also with some left over TPO roof and some more trim, all caulked so that issue should be dealt with
Can't afford another sheet of diamond plate right now ( no paying worky sucks ) for the front compartment, so....You guessed it, some more left over Roof some aluminum panel cap for the edge and viola...
The weather seal on the seam is Slide out seals for a power slide on a trailer and the aluminum is awning rail
Fantastic fan in, caulked with Dicor and wired
And my groovy switch panel and Battery level box above the door
Don't think thats gonn stay though, thinking a panel the width of the door with the switchs, battery level meter, Barometer and Humidity gauge and a thermometer, " MAYBE " a clock
Chris
Martiangod
Images: 432
power panel
Postby PcHistorian » Sat Feb 04, 2012 8:57 am
Maybe you can just some trim (wood, metal ) and build a flip open box that looks like trim if you didn't know that that was where you hid all your switches. Then you could do them on your way in or out of the place, check status, etc... use an old cabinet spring load latch to keep it shut. Or a magnetic latch.
Elf Cottage
Build Documentary
https://sites.google.com/site/pchistorian/home/hobby/camping/elf-build
Build Forum
http://www.tnttt.com/viewtopic.php?t=48462
Build Album
http://www.tnttt.com/gallery/album.php?album_id=42
progress is progress. (don't look a gift "progress" in the mouth.)
PcHistorian
Images: 198
Postby Martiangod » Sun Feb 05, 2012 4:45 pm
Its flying....
Trailer doesn't have brakes so that was on the list.
Don't know who built it but they made the axels and used bolt on hubs, probably from a car or pickup. SO...No brake flange.
SO pulled the axels today and going down to Cerka Trailers in Milton ON sometime this week and ordering a set of Dexter Axels, 1/w brake, 1 idler. Still undecided between 2200s or 3500's. Might as well put new springs on while I'm at it, It is going to be crossing the country Loaded after all.
Good thing I pulled things though, had a bad bearing on one anyhow
The old axels have a 3 inch drop, but I think i'm going with straight axels, Will probably be doing some rough country camping once I make the move to Alberta and that should also give me room for a holding tank below floor, I have a 32 gallon tank on hand so that should work for both Grey and Black.
Got it Jacked up to close to what should be ride hight and the 45 ' break on the nose of the trailer is about level with the top on my cap on the truck, so its all good
Whoever built this thing didn't plan on it falling apart, all the nuts where welded to the threads :cry:
Image[/quote]
Chris
Martiangod
Images: 432
Postby Martiangod » Thu Feb 09, 2012 11:04 pm
The trailer has landed
Back on her feet again
New Dexter 3500lb Axels with ezee lube hubs, Idler on the rear axel, 10" brakes on front and new springs.
Tires look really funny now, hopeing I have room for 15"'s but thats gonna have to waite for a while.
Ordered on Tuesday, They had to be built to my frame specs
Picked them up today at 1;30 today, 2.5 hour drive home, Installed and wheels back on it by 6;30 and sitting at the dinner table, mmmmm Pasta!
Have to wire the brakes tomorrow.
Sized it up for a below floor and insulation install of the black holding tank, should be no trouble at all. And thinking of a full width pass through storage box ahead of the wheels. Its high but it opens up some new possibilities and still be able to make it off roadable
Feel better now with some stopping power for the long haul loaded out west in the fall
Chris
Martiangod
Images: 432
Re: power panel
Postby Martiangod » Thu Feb 09, 2012 11:15 pm
PcHistorian wrote:Maybe you can just some trim (wood, metal ) and build a flip open box that looks like trim if you didn't know that that was where you hid all your switches. Then you could do them on your way in or out of the place, check status, etc... use an old cabinet spring load latch to keep it shut. Or a magnetic latch.
I'm actually thinking something along them lines, don't like the looks of what I did, it was a quicky
Chris
Martiangod
Images: 432
Postby WhitneyK » Fri Feb 10, 2012 9:19 am
I'm glad to see that you got warm enough weather to paint the inside of your fender wells while you had it apart. :D
Lookin' good man!
Whitney & Tracie
Crothersville, IN
WhitneyK
Images: 412
Re: Power of T morphs
Postby Martiangod » Tue Feb 14, 2012 6:08 pm
Been lazy since the axel swap. oh well.
Got back out there today for a bit, put the bottom in the front cross cabinet,
Moved the battery to the toungue box, One more to go, will run dual 24groups.
Should work out good up front, have room for 2 batteries and two 20lb propane tanks and the power cord, jack and a few more bits and pieces in the toungue box
Ran the cables in to the power strip, Hooked up the inverter, its only an 800watt, to run my CPAP machine :(
And sourced 4' x 10' . 040 Red aluminum sheet.
So with the red aluminum, i'm thinking might end up more like this
Red on top and charcoal grey on the bottom, to match my truck
Been pricing aluminum, and a utility builder wanted $300 for 4 x 10 off a roll. Found a Late Model race car manufacturer, $86 for 4 x 10 .o40 and I just happen to be heading down there tomorrow, so no extra driving expense.
Have to go to London for two days to set up our trailers for the RV Show this weekend,
Oh Joy, 4 hour drive each way, 2 days of polishing Everlites and IGO's, sorry, no Element in inventory
Sell and Service All composit Everlites and building my own trailer out of my old garbage trailer....lol
Chris
Martiangod
Images: 432
Postby Martiangod » Fri Feb 17, 2012 7:00 pm
Well picked up the Aluminum yesterday at 4;30 after setting up the London RV Show display, 1 1/2 days of polishing new trailers, what a joy.
3 hour drive home...glad thats over
So it wasn't a bad day today got up to 36 degrees, whoo hoo, outside work
Had to move the trailer so I could get to both sides, was up against the fence. Settles a little into some depressions, pulled it out by hand, spun it and shoved her sideways in the drive, must have been all that Wax on, Wax off that got me in fine Karate Kid physical condition
them 4 x 10's were fun, little windy and by myself, but I persevered,
rigged up some bottom supports and had some 2x2' and 2 1/2 screws for quick preasure supports to the sides to keep the wind from blowin me and the aluminum away
Color is pretty close to the truck, which makes me happy
Front corner trimmed, think i'm going to change out the white rv trim for1 x 1 aluminum angle when I get back to work
Have to get some corners for the back yet
Love the red to checkerplate contrast
And got the window cut, installed and caulked
Need to find a small window for the roadside also
Picked up some jeep style hood catches, have to mod them a bit to hold down the hatch on the front storage compartment , never made it that far today :)
Oh well, theres always tomorrow....I hope
Chris
Martiangod
Images: 432
