Generator
Generator
Postby Dahlia47 » Sun Jun 20, 2021 2:15 pm
What am I missing here? When we tried to run this, gas poured out everywhere! These are the only lines we see. I dont know where the gas was leaking from. We looked inside and out and all the other lines are connected. Any ideas? Throw'em at me! Image
Sent from my IN2017 using Tapatalk
Dahlia47
Re: Generator
Postby friz » Sun Jun 20, 2021 2:33 pm
Is it on its side? If thats the case the float in the carb will not work an fuel will come out the intake. Otherwise possibly a stuck float in the carb bowl. Sometimes a few taps on the side of the float bowl will make it behave.
Sent from my SM-G965U using Tapatalk
The "Sin Bin"
150133
friz
Images: 6
Re: Generator
Postby Dahlia47 » Sun Jun 20, 2021 4:31 pm
I leaked when it was upright. Completely emptied. Where is the float bowl?
Dahlia47
Re: Generator
Postby Socal Tom » Sun Jun 20, 2021 5:10 pm
What brand/model is it?
Socal Tom
Re: Generator
Postby featherliteCT1 » Sun Jun 20, 2021 6:13 pm
The float bowl is the underside of the carburetor. I wonder if the float bowl has a drain valve/screw with a drain fuel line that was left open. If so, shut the valve off.
If drain valve was shut, you might try pouring a pint or so of gas into the tank with the side cover off while you simultaneously look to see where the fuel is flowing out from.
If fuel is draining out the overflow tube on the carburetor i would suspect the float valve inside the bowl is stuck (like Friz said)
featherliteCT1
Re: Generator
Postby twisted lines » Sun Jun 20, 2021 7:06 pm
featherliteCT1 wrote:The float bowl is the underside of the carburetor. I wonder if the float bowl has a drain valve/screw with a drain fuel line that was left open. If so, shut the valve off.
I think that the green screw near green dot on hose may be a bowl drain screw ?
Racking up; And Rapin foam
twisted lines
Re: Generator
Postby rjgimp » Sun Jun 20, 2021 7:24 pm
That shiny silver cylinder thingy in the middle of the top half of the photo just below where you are pointing is the carburetor bowl. The screw on the bottom is holding it on and the screw on the side is the drain. There is a gasket sealing the top of the bowl. If that is askew and the float inside is sticking, gas will indeed exit the top of that bowl like a fountain.
:frightened:
-Rob
rjgimp
Images: 7
Re: Generator
Postby Dahlia47 » Tue Jun 22, 2021 9:35 am
We got the gas leak stopped, but now it will start and then immediately stop. We checked the filter, it is clean. We checked the oil, it is full and clean.
Dahlia47
