Sent from my IN2017 using Tapatalk
featherliteCT1 wrote:The float bowl is the underside of the carburetor. I wonder if the float bowl has a drain valve/screw with a drain fuel line that was left open. If so, shut the valve off.
If drain valve was shut, you might try pouring a pint or so of gas into the tank with the side cover off while you simultaneously look to see where the fuel is flowing out from.
If fuel is draining out the overflow tube on the carburetor i would suspect the float valve inside the bowl is stuck (like Friz said)
