filling holes and voids
Postby rbaumbauer » Wed Apr 04, 2012 9:24 am
I have alot of screw holes to fill and few goos sized voids on the ext. i was thinking of useing liquid nails on the out side and thoughts
9029790296
rbaumbauer
Images: 81
Re: filling holes and voids
Postby Kharn » Wed Apr 04, 2012 9:58 am
How are you going to finish the exterior? Paint, aluminum, stain?
Kharn
Postby rbaumbauer » Wed Apr 04, 2012 10:20 am
going to finish with boat paint amd epoxy.
rbaumbauer
Images: 81
Postby parnold » Wed Apr 04, 2012 10:57 am
I like Bondo because it hardens so fast and you can start sanding within minutes. Many have created different concoctions with sawdust and epoxy, microspheres and epoxy, etc. If paint is going on top, save yourself a lot of time and use Bondo.
parnold
Images: 302
Postby CliffinGA » Wed Apr 04, 2012 11:57 am
They also make a bondo patch thats epoxy and fiberglazs strands that sorks for large area's also.
Cliff
My Build:
viewtopic.php?f=50&t=42628
CliffinGA
Images: 207
Postby rowerwet » Wed Apr 04, 2012 12:47 pm
I used the same as the TD was put together with, PUpremium, I have no fasteners in my TD except those needed to hold the box on the frame, and the door hinges. the adhesive is tough enough to tear the wood apart, and fasteners cause leaks/rot
rowerwet
Images: 521
Postby rowerwet » Wed Apr 04, 2012 1:12 pm
rowerwet
Images: 521
