How about this for a trailer
Postby atl_westend » Mon Apr 23, 2012 8:21 pm
How about this for a starting point, This seems like this would work great.
trailer .jpg (72.67 KiB) Viewed 320 times
atl_westend
Re: How about this for a trailer
Postby 48Rob » Tue Apr 24, 2012 6:51 am
I like it.
It would make a cool rear entry full fendered trailer!
Rob
48Rob
Postby atl_westend » Tue Apr 24, 2012 6:53 am
It looks like a bunch of people looked at this but did not comment, Is this not a good trailer to build a camper on? I am a newbie so I have no idea. I am going to go look at it today
Thanks
atl_westend
Postby atl_westend » Tue Apr 24, 2012 6:55 am
48Rob wrote:I like it.
Rob
Thanks 48Rob That is what I was thinking
atl_westend
Postby 48Rob » Tue Apr 24, 2012 7:03 am
There may be a lot of hesitation, as teardrops are the main focus here, and that setup instantly throws up a roadblock because the fenders are in the way of a typical teardrop door(s).
Having tandem axles is a bit overkill, but it has been done.
With the look you have now, a low swoopy shape to compliment the fenders would look really good, but probably wouldn't look like a typical teardrop.
If you were thinking about buying the trailer and tossing the fenders and extra axle, it would be okay for a typical teardrop, but you may be better off in the long run to have a custom frame built to suit your plans/size, instead of the other way around.
It can get expensive very quickly trying to modify a frame to fit a trailer.
Rob
48Rob
Postby GPW » Tue Apr 24, 2012 7:19 am
I kinda’ like the fact the bed is so low to the ground... 8) ... and being tandem , couldn’t you run smaller wheels to get even lower (within reason of course) ... ???
If you already own it , then build something on it ( “Use what ya’ got!!!” ) ... a Foamie perhaps would be quick and even removable ... :thinking:
Couple more cross braces wouldn’t hurt either ... :o
Postby Martiangod » Tue Apr 24, 2012 7:30 am
Looks like an old horse trailer frame with drop axels, probable 3500 pound axels.
Definatly great for a rear entry build as Rob said.
Should track well.
And from the look of the framing, you could go two level, bed/couch up front where the frame rails are on top, and extra few inches headroom at back where frame rails to the bottom
Chris
Deep in the Heart of Nowhere
Martiangod
Images: 432
Postby atl_westend » Tue Apr 24, 2012 8:16 am
thanks guys it is an old horse trailer
it's very cheap this is why I am looking at it. it has two drop axles so it's low to the ground already.
I was thinking I could build some modified version of the Wandere 10 on it and yes have a door in the back.
atl_westend
Postby GPW » Tue Apr 24, 2012 8:20 am
QUOTE: “ it's very cheap this is why I am looking at it.” ... :thumbsup: 8) :D
Postby bc toys » Tue Apr 24, 2012 8:59 am
Yes I have looked at this a few times I think you can do 2 builds with this trailer or a big single trailer. Looks like you could build your bed crossways up front. There is lots you could do with this trailer. My vote is go for it and have fun.
bc toys
Images: 42
