poll where does the battery go?
Re: poll where does the battery go?
Postby kayakdlk » Tue Apr 12, 2016 8:52 pm
On the outside in a battery box for easy acess and centered over the axle. Same for my propane tank, but opposite side.
Dan
kayakdlk
Images: 392
Postby capnTelescope » Wed Apr 13, 2016 4:26 pm
In the galley, just behind the axle. With the propane tank in the tongue box and the spare tire in front of that, my tongue weight is just about all I can lift.
Brad
Building the Bed & Breakfast
capnTelescope
Images: 368
Postby Gary and Cheri » Wed Apr 13, 2016 5:07 pm
The battery and your spare tire are two items which have significant weight and do not need to be in a particular location to function well. As you are designing your tear you need to consider tongue weight. If your tongue weight is getting to heavy move both towards the rear and if to light adjust forward. To little tongue weight or to much is going to result in a trailer that does not tow well. Use these two easily moved items to get the best ride you can.
Gary
Gary and Cheri
Postby PKCSPT » Wed Apr 13, 2016 8:28 pm
I enjoyed this question, it is something I am trying to figure out myself. No place to put it in the rear and to heavy on the tongue with my other gear.
Maybe on the floor of my car and move it when I get there?
121172 116946 159644
PKCSPT
Images: 61
Postby Graniterich » Wed Apr 13, 2016 10:29 pm
PKCSPT wrote:I enjoyed this question, it is something I am trying to figure out myself. No place to put it in the rear and to heavy on the tongue with my other gear.
The reason I love my drop is that it is ready to go, very little setup. Moving and connecting the battery takes away from vision!
Graniterich
Postby PKCSPT » Wed Apr 13, 2016 11:10 pm
That's my dilema, small tongue which is where I carry my side tent. I can't permanently mount the box if I want to be able to open the lid, Hmm mmm I will figure something out.
PKCSPT
Images: 61
Postby Socal Tom » Thu Apr 14, 2016 3:15 pm
I see the pro's and con's like this
On Tongue
Pros
leaves more space in the galley
balances weight in the galley
venting is easy in a battery box
Cons
Long power lines from the tongue back to the galley and main power distribution area ( unless you can put it up front)
A big chunk of weight on the tongue
Uses space that could be used for wood or other "dirty" stuff.
In Galley
Pros
Balances weight on the tongue ( Lets face it, anything in front of the axle adds tongue weight, so a light tongue usually isn't a problem)
Shorter run to the power distribution. ( most of us put our power panels near the galley bulkhead, so you can save wire and trouble this way)
Cons
uses galley space which can be valuable space
might need some provisions for venting ( not a problem for me)
Socal Tom
Postby capnTelescope » Thu Apr 14, 2016 4:57 pm
Socal Tom wrote:I see the pro's and con's like this ...
Don't forget about putting the battery in the basement. :D
Pros:
Battery is out of the way, saves space in the galley and the tongue box.
doesn't contribute to tongue weight as bad as in the tongue box.
Easy venting.
Ready to go. (same for everything except the car trunk)
Cons:
Inaccessible for service/maintenance
Loss of ground clearance.
Complicates design and construction.
Brad
capnTelescope
Images: 368
Postby Socal Tom » Thu Apr 14, 2016 6:12 pm
Pros:
Easy venting.
Cons:
Con, you need to build a basement ;-)
Socal Tom
Postby capnTelescope » Thu Apr 14, 2016 7:31 pm
Socal Tom wrote:Con, you need to build a basement ;-)
:lol: :thumbsup:
Brad
capnTelescope
Images: 368
Postby Graniterich » Thu Apr 14, 2016 10:07 pm
Pros, don't need to move battery every time!
Graniterich
Postby Socal Tom » Fri Apr 15, 2016 10:29 pm
:lol: :thumbsup:
I've been tempted to build a drop down for the battery below the galley, I think I could fit it under my fridge drawer if I just dropped it a few more inches. But I can't seem to get the motivation to cut the hole in the floor.
Socal Tom
Postby capnTelescope » Sat Apr 16, 2016 12:25 pm
Socal Tom wrote:I can't seem to get the motivation to cut the hole in the floor.
:frightened: It was scary enough just drilling a couple of holes thru the floor. Building a basement for 75-100# to bounce around? Double scary. :frightened: :frightened:
Brad
capnTelescope
Images: 368
Postby Socal Tom » Sun Apr 17, 2016 9:03 am
I went to carrying my spare in the TV. It was easier to work around that easy, and saved the weight of a carrier.
Sent from my Lenovo A7600-F using Tapatalk
Socal Tom
Users browsing this forum: backyardlegend, Bing [Bot] and 1 guest
