On the outside in a battery box for easy acess and centered over the axle. Same for my propane tank, but opposite side.
Dan
PKCSPT wrote:I enjoyed this question, it is something I am trying to figure out myself. No place to put it in the rear and to heavy on the tongue with my other gear.
Maybe on the floor of my car and move it when I get there?
Graniterich wrote:PKCSPT wrote:I enjoyed this question, it is something I am trying to figure out myself. No place to put it in the rear and to heavy on the tongue with my other gear.
The reason I love my drop is that it is ready to go, very little setup. Moving and connecting the battery takes away from vision!
Socal Tom wrote:I see the pro's and con's like this ...
capnTelescope wrote:Socal Tom wrote:I see the pro's and con's like this ...
Don't forget about putting the battery in the basement.![]()
Pros:
Battery is out of the way, saves space in the galley and the tongue box.
doesn't contribute to tongue weight as bad as in the tongue box.
Easy venting.
Ready to go. (same for everything except the car trunk)
Cons:
Inaccessible for service/maintenance
Loss of ground clearance.
Complicates design and construction.
Socal Tom wrote:Con, you need to build a basement ;-)
capnTelescope wrote:Socal Tom wrote:Con, you need to build a basement ;-)
Socal Tom wrote:I can't seem to get the motivation to cut the hole in the floor.
