Anyone use this Door Hinge???
Postby Loader » Fri Jul 01, 2011 7:05 pm
Been looking a few different style of door hinges, and this one caught my eye.
I know, I know, the quick release pin isn't the most secure, (probably just enough to keep someone honest) but the look of the hinge is pretty nice.
Anyone use these?
http://www.mcmaster.com/#lift-off-hinges/=d008uo
Earl & Kerry
"Loader"
Loader
Images: 245
Postby aggie79 » Fri Jul 01, 2011 7:17 pm
Earl,
I think Thomas (2bits) used these hinges. I believe he replace the quick release pin with a nylon bushing and bolt and nut.
Take care,
Postby Loader » Fri Jul 01, 2011 9:07 pm
Thanks Tom.
I went and looked at Thomas' build thread, and, there they were! With all the times I have seen Thomas' trailer, would think I should have noticed them.
Thanks again!
Earl & Kerry
"Loader"
Loader
Images: 245
Postby 2bits » Sat Jul 02, 2011 9:30 am
Yup! Bought from http://www.discountmarinesupplies.com/Seadog_Long_Reach_Stainless_Hatch_Hinges.html
for $14.95 and this is the long-reach version. This was the cheapest I found and there was a WIDE variance in pricing on these things.
Tom you are partly right, I did not replace the pin with a bolt and nut, but I did put a nylon washer from a box store in the gap between the two hing pieces which took out most of the wobble nicely.
Also because of the door jamb trim and the T molding on top of that, the door set out almost an 1/8" inch, so I trimmed out a leftover piece from my plastic hatch hinge and used it as a spacer would be level on the body and the door.
Thomas
2bits
2bit Member
Postby Loader » Sat Jul 02, 2011 9:47 am
Thanks Thomas!
So, no bolt and nut, kept the quick release pin but add nylon washers - Got it.
Appreciate the link too, $3 per hinge cheaper than McMaster-Carr.
Earl & Kerry
"Loader"
Loader
Images: 245
