what the f
what the f
Postby rbaumbauer » Sun Apr 01, 2012 10:02 pm
put tar on last night got up this morning ply all seperated what happened
rbaumbauer
Images: 81
Re: what the f
Postby campmaster-k » Sun Apr 01, 2012 10:45 pm
rbaumbauer wrote:put tar on last night got up this morning ply all seperated what happened
Pictures please. :pictures:
-Kirk
>CEO Coleman Recovery Inc.
Build thread -
Check out my Pictures -
campmaster-k
Re: what the f
Postby parnold » Sun Apr 01, 2012 10:59 pm
also post what brand of tar. sounds to me like the tar had a high solvent content which reacted with the glue in the plywood. I've never heard of this before, but it's the only thing in my mind that makes sense.
parnold
Images: 302
Re: what the f
Postby Jim Edgerly » Mon Apr 02, 2012 9:01 am
Were you using marine grade plywood or just "indoor" plywood?
*When doing anything, if there exists no possibility of failure, then any feeling of success is diminished.
**The glass is neither half full nor half empty...it is simply twice as big as it needs to be.
***If at first you don't succeed, redefine success.
****When I die, I want to die like my grandfather, who died peacefully in his sleep. Not screaming like all the passengers in his car.
Jim Edgerly
Images: 142
Re: what the f
Postby rbaumbauer » Mon Apr 02, 2012 10:26 am
I am useing 1/2 in ext grade non sanded for floor. the only thing I can think of is I heated the tar a bit for easy rolling in cold shop just warm tho not boiling or anything :x I think ill just have to cut a patch dont want to try and pull the whole sheet its all glued and srewed dont see that going well. another lessoned learned i guess. :cry:
rbaumbauer
Images: 81
Re: what the f
Postby rbaumbauer » Tue Apr 03, 2012 12:29 am
found it was just bad ply alot of voids all in the same spot. it was a none solvent tar
rbaumbauer
Images: 81
Re: what the f
Postby GPW » Tue Apr 03, 2012 5:30 am
Well, it would appear the Chinese have found a way to make their plywood even WORSE than it was before :twisted: ... Maybe it’s time we just STOP using it all together ... :o That’s THE WISE THING TO DO !!!
Better if some would compose a letter ( representing the thousands of us ) to the big box stores that handle this stuff and let them know , We aren’t going to buy this anymore ...( Viral You Tube rant might not hurt either) The consumers have the Power , if the stores are informed of their loss , then they might (maybe) get some decent products once again ... Selling a product at a price point (cheap as possible, with the Most Profit ) really doesn’t work if the product is total Crap ... Something the RV industry is currently having to deal with ... :frightened:
The Logical thing to do here is make a List (post it here) of what is Good plywood and what is BAD (do not use ) plywood .... That way the members and prospective builders would be fore-warned , and we wouldn’t have to see the pics , and listen to all the whining about all those beautiful build projects turning to MUSH !!! :thumbdown:
That or find a more Reliable alternative ... :thinking:
Re: what the f
Postby mckenney56 » Tue Apr 03, 2012 10:31 am
I found some fairly large voids is my quarter inch CDX ply.
It is a Georgia Pasific product, but I don't know where it is actually made. I got it at Lowe's.
mckenney56
Images: 129
Re: what the f
Postby rbaumbauer » Tue Apr 03, 2012 11:48 am
home depot here wish I would have went with my gut and done a 3/4 floor. oh well too late now. remember those voices in your head have a point sometimes.
rbaumbauer
Images: 81
Re: what the f
Postby KCStudly » Sun Apr 08, 2012 12:30 am
rbaumbauer wrote:Remember those voices in your head have a point sometimes.
90469
Re: what the f
Postby Gage » Sun Apr 08, 2012 4:18 am
How many times does it need to be said? When you buy ply from a big box store, you’re buying junk. Always buy your ply from a lumber yard. Yea, it cost more but you won't have the problems you’re having. You get what you pay for. :o
Image Image Image
Gage
Images: 28
what the f
Postby aggie79 » Sun Apr 08, 2012 7:37 am
+1 on what Gage said. The only decent plywood I've found in at the BORG or the blue version is some Arauco plywood at Lowes. It is made in South America and it sells for a premium.
If you don't have a good lumberyard or specialty plywood shop in your area try asking a cabinet shop or sign shop.
Re: what the f
Postby working on it » Sun Apr 08, 2012 8:46 am
That's what I'm using...I'm glad to see that an experienced builder like him judged it sound. I had some second thoughts about it, since it was tagged as interior "cabinet grade" at the store; but presanded ACX really looked good to me... flat, smooth,no discernable defects (I bought it on sale too!). I had wondered if the glue would dissolve when soaked thru with 50/50 mix poly/mineral spirits, but my test pieces came out solid. Here in the interior of Texas, marine plywood is really never seen, so I bought the best I could for the money.
173193172890148599
working on it
Images: 457
Re: what the f
Postby working on it » Mon Apr 09, 2012 10:28 am
In reference to my above posting concerning the plywood I am using for my build, I have some reassuring (to me) info about Arauco plywood . I only now viewed the Arauco website (should've done so before purchase ! ,> a no-brainer) and found this:
Adhesive
All AraucoPly panels are laid up with phenolic WBP glue which is suitable for exterior use.
It now seems that I've been overly worried over the suitability of this plywood for exterior use for the last 6 months. I've been expecting ply separation at any time from glue failure when I coated with solvent based polyurethane. Not so much concern now! I've used phenolic carburetor spacers on my racecar, and they resist racing fuel with no problems, so I figure that the phenolic glue in the Arauco should be impervious to solvent (and hopefully, water). A polyurethane, then enamel coating over this plywood may turn out OK after all.
173193172890148599
working on it
Images: 457
