how perfect a curve?
Postby Bigblock352 » Fri May 23, 2014 4:36 pm
This might be a dumb question but...
I'm building a rimple. All wood. No aluminum skin. How perfect does the curve have to be for the walls where the roof mounts? I'm not talking way off but maybe a 1/16 dips.
120505120504
Bigblock352
Images: 39
Re: how perfect a curve?
Postby citylights » Fri May 23, 2014 4:42 pm
1/16th is not much. Maybe a little sanding to smooth them out?
citylights
Postby Bigblock352 » Fri May 23, 2014 4:51 pm
I've been sanding to get it down to a 16th. Just didn't know if I needed to keep going. To make it perfect or was that in "tolerance"
How does everyone else make these curves? Better jigsaw skills than me I bet lol :)
Bigblock352
Images: 39
Postby Wolfgang92025 » Fri May 23, 2014 5:45 pm
BigBlock
Use a belt sander and place it on its side. Clamp it to the table and put a spacer block in front of it for the offset in sand paper height. Now you can sand up the the line in a flash.
Wolfgang
Wolfgang92025
Images: 660
Postby 48Rob » Fri May 23, 2014 7:05 pm
Bend a piece of thin cardboard around the radius, you will know right away if you need to do more sanding.
Rob
48Rob
Postby Bigblock352 » Fri May 23, 2014 9:03 pm
Great advice. Thanks! :applause:
My idea is to get this perfect once then use that as a template for a router to make 4 exactly the same curves.
Bigblock352
Images: 39
Postby Fyddler » Tue May 27, 2014 11:50 am
Clamp the two sides together when sanding, that way they are exactly the same.
To err is human, to really foul up requires a computer
Build Log: http://www.tnttt.com/viewtopic.php?f=50&t=55017
Fyddler
