The Crab Needs A New Shell--Any Ideas?
Postby GPW » Thu Aug 30, 2007 6:55 am
How about the Old School felt and canvas top??? worked for the old timers.... :roll:
Postby john » Thu Aug 30, 2007 9:02 am
I haven't used formica on a trailer but I have had left over bits from kitchen renovations. I use prefab counters in my rentals and have left the extra out in the weather to see how it would hold up.
In one case the scrap was the hole cut out for a sink. It sat in an area that got a little sun, a bit more shade later in the day and whatever rain that fell. The formica showed no wear at all in the year and a half it sat. The press board that the formica was glued to, though did what press board does when it gets wet.
I considered using it on my tear but it cost as much as aluminum and some of the other members here brought up the shattering issue. Formica may not take a sharp hit very well.
It may be the answer in your case, though.
Build I -- Scenic ---
http://www.flickr.com/photos/8121727@N04/
Goto the Tear Build file
Build II -- Scenic II ---
viewtopic.php?t=29603
Build III -- Scenic Solo---
viewtopic.php?f=50&t=50324
Travel Blog----Now without Political Commentary
http://polifrogblog.blogspot.com/2009/0 ... -2009.html
The Constitution was ratified, not an interpretation thereof...
Penomeli ikibobo
john
john
Images: 261
Postby caseydog » Thu Aug 30, 2007 10:08 am
Jiminsav wrote:Ira, I got that stuff from http://yourautotrim.com
it's a ebay store, and they have tons of different vinyls.
I keep mine in the yard and so far, no problems.
(knocking on my head)
Vinyl top material is fine outdoors, as long as it is washed regularly, and you put a UV inhibiting vinyl protector on it from time to time. I think it looks cool on a TD, too.
My build journal is HERE
caseydog
Images: 515
Postby caseydog » Thu Aug 30, 2007 10:10 am
GPW wrote:How about the Old School felt and canvas top??? worked for the old timers.... :roll:
You can get vinyl with that canvas look to it. MUCH easier to keep than real canvas, I would think.
caseydog
Images: 515
