Stainless Steel
Stainless Steel
Postby cguardsman » Wed Sep 12, 2007 11:14 am
I have a chance to buy 2 sheets of stainless 22 ga. is that thick enough to skin the top of a tear with??
Craig
cguardsman
22 gauge ss
Postby eamarquardt » Wed Sep 12, 2007 11:33 am
According to the chart 22 gauge in SS is .034". I would think (given most are using .040 aluminum) that it would be ok. Check on the weight compared to Al. Depending on the alloy you can cut it with a jig saw using a bi metalic blade (not the cheap blades) going slow and keeping the blade cool with water or, wd40, or some other suitable coolant. Is two sheets going to cover your project?
Cheers,
Gus
eamarquardt
Images: 150
Postby kerryd » Wed Sep 12, 2007 11:53 am
Try an air shear or electric shear . They will go though the metal like butter . Keep the jaws lubed good . Kerry
kerryd
Postby Mary K » Wed Sep 12, 2007 1:02 pm
Just a thought, Its gonna be mighty heavy compared to aluminum!
Mk
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby cguardsman » Wed Sep 12, 2007 1:25 pm
i'm not overly concerned with the weight as it will likely just be used for the top and hatch but i can get two 5'x10' sheets for 150. sounded like a deal to me?? :twisted:
Craig
cguardsman
ss price
Postby eamarquardt » Thu Sep 13, 2007 1:18 am
I in Nov. 06 I bought 5 sheets of .040 5'X12' 5052 al for $85.48/sheet. Don't know what the current price is but you can call THyssen Krupp Materials at 800-926-2600 in Santa Fe Springs, Ca. and they have facilities accross the country.
Good luck,
Gus
eamarquardt
Images: 150
Postby madjack » Thu Sep 13, 2007 1:35 am
Craig, that sounds like a heckuva deal to me...I say...gofrit........................... 8)
