headboard upper cabinet - good idea or bad
Postby aggie79 » Mon Nov 03, 2008 1:24 pm
Good idea or bad? :thinking:
I'm needing to get a little more interior storage space in my design. I don't have room for a lower cabinet at the front, but was thinking about an upper cabinet or shelf above the pillows.
Thanks for your thoughts.
Re: headboard upper cabinet - good idea or bad
Postby CaptainKram » Mon Nov 03, 2008 1:54 pm
aggie79 wrote:Good idea or bad? :thinking:
Not a bad Idea. :thinking: Just don't forget it's there when you wake up in thte morning! ;) :D :D
Mark
"A woman drove me to drink, and I didn't even have the decency to thank her." ~W. C. Feilds
CaptainKram
Images: 6
Postby Kens » Mon Nov 03, 2008 2:11 pm
We have the upper front cabinet its great for all the small stuff. Look in my album.
Good day every day!
Kens
Images: 26
Postby john » Mon Nov 03, 2008 4:01 pm
I have an upper cab. above my pillows but it is small. It could have been larger but the shape of my trailer (profile) cut into potential cab. space. A benroy profile helps with space.
I used the cab space above the pillows for a couple of fluorescent lights. They shine on the ceiling and set it to a glow. This eliminates the glare of a direct light in the eyes.
It also helps me sit up with a hand hold.
Build I -- Scenic ---
http://www.flickr.com/photos/8121727@N04/
Goto the Tear Build file
Build II -- Scenic II ---
viewtopic.php?t=29603
Build III -- Scenic Solo---
viewtopic.php?f=50&t=50324
Travel Blog----Now without Political Commentary
http://polifrogblog.blogspot.com/2009/0 ... -2009.html
The Constitution was ratified, not an interpretation thereof...
Penomeli ikibobo
john
john
Images: 261
Postby NightCap » Mon Nov 03, 2008 4:58 pm
I made a small one that holds some stuff. Like wallets, flashlights keys etc. Wider corners for the lights.
#1 - 100% Done #2 - 100% Done Thinking about #3
NightCap
Images: 259
Postby Eunice » Tue Nov 04, 2008 12:40 pm
wouldnt work in our Kit style. We would hit our heads and Kenny and I sit up to watch movies. I hung a fishnet across the back in front of the cupboards to hold simple things like flip flops and hats.
Eunice
former director
Jefferson State Chapter
TearJerkersImage
Eunice
Jefferson State Tearjerker
Images: 109
Postby planovet » Tue Nov 04, 2008 12:51 pm
Just make sure you don't bump your head, it's a complaint I have heard from others. I built mine into the front curve of mine, although your design isn't the same as mine.
Gig 'em Aggies!
ImageMark (& Cindi)
planovet
The Cat Man
Postby aggie79 » Tue Nov 04, 2008 5:52 pm
Thanks for they replies. :applause: I'll probably go with a shallow shelf placed high up for eyeglasses, wallet, keys, etc.
Postby 48Rob » Tue Nov 04, 2008 6:45 pm
If your tear isn't built yet, lay on the floor in the corner of a room.
Have someone mark the arc your head makes as you "get up" from a sleeping position.
That will quickly show you how much projection your shelf or cabinet can have before causing a headache.
Rob
48Rob
Postby bobhenry » Wed Nov 05, 2008 10:03 am
We sleep with our heads at the galley wall and I have never stubbed my toe on the front cabinets.
Postby mechmagcn » Wed Nov 05, 2008 10:06 pm
We have a headboard and an overhead shelf, thinking of putting another shelf in between.
Jeff & Micki
53 F100
Mercedes turbo diesel
Teardrop "finished" as if they ever are
You can never be lost if you don't care where you are going!
mechmagcn
Images: 56
