TENNJIM wrote:doug hodder wrote:I've got Coleman white gas stoves and drill the foot bumps on it and through bolt it with a wing nut...makes it removeable. You'd want to make sure that there is an air gap under your stove. Doug
I did the same thing with a Coleman propane stove. Mounted it to a slide-out from my galley.
Jim B / Utah
How do you keep the sliders locked out to prevent a lit stove from rolling under the counter top?
