Carbon skinned teardrop
Postby Vindi_andy » Thu Jun 10, 2010 4:03 am
Mike this is the Carbon effect ABS sheet the kit car guys use
The only drawback is the place in the UK dont do it in big sheets but i guess some platic manufacturer might.
Boys never grow in to men the toys just get more expensive and more dangerous
How true :)
Vindi_andy
Images: 49
Postby Carter » Thu Jun 10, 2010 4:14 am
Mike
At work we use a lot of vac bagged pre-preg carbon. Perfect if you want to spend a huge amount of money.
Jim
I need a new Avatar. I'd put my dog up there but she doesn't look much like me. She's the skinny one.
Carter
Images: 32
Postby Vindi_andy » Thu Jun 10, 2010 5:28 am
These guys do 1m x 1m x 2.5mm thick sheets of Carbon effect ABS They may be able to do bigger but it wont be cheap
http://www.ukplastics.co.uk/2mm_abs_car ... _sheet.htm
How true :)
Vindi_andy
Images: 49
Postby Arne » Thu Jun 10, 2010 9:52 am
With carbon weave, do you use the same type of resin as with Fiberglas?
And is the process the same, put down resin, lay carbon on top and apply more resin and squeegee it in to remove air?
wonder how you see trapped air if it is black...
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby glassice » Thu Jun 10, 2010 12:58 pm
best to use exp y it bonds has to have high heat to cure right if not it just incapable the carbon best with preprages the way we do if not using preprages is dry bag that way you can keep it strait then use vacuum infused resin. if you have a lot of help you can lay down and wet out but it will not be strait better Chance it will be a big mess
It is not the return ON my investment that I am concerned about; it is the return OF my investment
glassice
Postby Carter » Fri Jun 11, 2010 3:57 am
Arne
We use epoxy on both fiberglass and carbon. If carbon we normally vac bag it with plastic to press the layers together. In situations where the part has to be extremely light or pretty we use pre-preg carbon. The correct amount of resin is in the cloth. It is stored in freezers until used. It is cut and layered in the mold and then vac bagged until it cures in a large oven. Beautiful finish, extremely light, very expensive.
Jim
Carter
Images: 32
