Thus Begins NightCap's TTT Build
Postby doug hodder » Sun Sep 28, 2008 2:55 pm
Just treat it like a teardrop profile. Doug
Postby NightCap » Sun Sep 28, 2008 3:02 pm
doug hodder wrote:Just treat it like a teardrop profile. Doug
Ok, thanks, I have it pictured now.
I decided on a better floor plan because I see it being difficult to get seated by the sink area.
Seems a lot cleaner too.
#1 - 100% Done #2 - 100% Done Thinking about #3
NightCap
Images: 259
Postby 2bits » Sun Sep 28, 2008 5:56 pm
seems like there might be a dead/unused space in the bathroom corner, any way you can put the potty in the corner at a 45', or maybe put the sink in that dead corner next to the john and then you will have a little more kneecap room, and could put a shallow closet there in it's place?
Thomas
2bits
2bit Member
Postby NCrado » Sun Sep 28, 2008 8:48 pm
I really like your design. We started out to build a tear, then went to something like your building and I guess we're going to end up with something in between!
I know, my vent's bass ackwards!
NCrado
Postby john » Sun Sep 28, 2008 11:12 pm
I have considered a toilet in a small standie also. I wonder if the toilet could be installed where your stove is with its back to the tongue.
When the potty door is closed it could nearly rest against the front of the toilet. Also with the potty door closed there would be room enough only for the toilet in the bath room. When opened all the way the unhinged edge could connect with the wall across the hall that the toilet "faces". When the bathroom is in use the floor in front of the trailer exit door would be in the bathroom. When not in use that same floor would be a hall or entry area for the trailer exit door. The floor in front of the exit door would have a dual use. Dual use empty space.
Of course you would need a wall across from your toilet. Your diagram does not show one. Also a bifold door may be required unless stepping outside the trailer to fully open the bathroom door is appealing.
Might save some space. :thinking: :thinking:
I thought that I might add that a sink installed in the kitchen can also be used as a sink for bathroom needs. This would free up room in a small bathroom.
Build I -- Scenic ---
http://www.flickr.com/photos/8121727@N04/
Goto the Tear Build file
Build II -- Scenic II ---
viewtopic.php?t=29603
Build III -- Scenic Solo---
viewtopic.php?f=50&t=50324
Travel Blog----Now without Political Commentary
http://polifrogblog.blogspot.com/2009/0 ... -2009.html
The Constitution was ratified, not an interpretation thereof...
Penomeli ikibobo
john
john
Images: 261
Postby NightCap » Mon Sep 29, 2008 12:42 pm
2bits wrote:seems like there might be a dead/unused space in the bathroom corner, any way you can put the potty in the corner at a 45', or maybe put the sink in that dead corner next to the john and then you will have a little more kneecap room, and could put a shallow closet there in it's place?
I hear what you are saying but one thing I forgot to draw on my plan was the drain hole.
I thought that space could be a standing shower area.
I am taking input all the time though, because when it comes time to build the bathroom I'm sure I will use chalk lines on the floor and move stuff around for a good fit.
John's ideas are interesting as well. I like it. I guess you would have to make dang sure you lock your entry door. :o Or there could be some surprised people.
Thanks again for all the great input.
NightCap
Images: 259
Postby john » Mon Sep 29, 2008 4:30 pm
Ah!! ok :thumbsup: :thumbsup:
Penomeli ikibobo
john
john
Images: 261
Postby 2bits » Mon Sep 29, 2008 8:34 pm
yeah now yer talking! hmm but you know you could keep the drain hole and just put the potty right over it and kill two birds with one stone! :lol: Just kiddin, that looks real good actually.
Thomas
2bits
2bit Member
Postby Micro469 » Mon Sep 29, 2008 11:41 pm
I don't know if you plan to mount the potty to the floor or not, but if you used a porta potty you could put it wherever you wanted, and take it out when you take a shower.....
John
Micro469
Images: 382
Postby NightCap » Tue Sep 30, 2008 11:22 am
Micro469 wrote:I don't know if you plan to mount the potty to the floor or not, but if you used a porta potty you could put it wherever you wanted, and take it out when you take a shower.....
Hmmm. Really good point. It would make the bathroom take up less room. Something to think about. Thanks John.
NightCap
Images: 259
Postby cuyeda » Tue Sep 30, 2008 5:05 pm
You may be headed in a different direction by now with the porta potti. I don't know if any of these shower/pan combos would be good for your design ideas... There are several options here, some with onboard holding tanks.
Click Here!
If you have enough room in a sidewall, how about a cassette toilet.
Cliff & Vanessa
cuyeda
Postby NightCap » Wed Oct 01, 2008 8:16 am
How does a cassette toilet work? Do you have to dump it through a hose or at a station?
NightCap
Images: 259
Postby cuyeda » Wed Oct 01, 2008 12:38 pm
NightCap wrote:How does a cassette toilet work? Do you have to dump it through a hose or at a station?
Thetford's cassette toilet is a permanent mount. You dump it the same way a porta pottie is serviced. An access door will have to be installed on the outside wall adjacent to the toilet installation. The holding tank can be serviced through the access door from the outside. There are two models of the cassette toilet. One model will allow a direct connection to an onboard water tank to draw water used for flushing. With this feature, you don't have to fill two separate water sources.
You don't have to wrestle the entire toilet to service it.
No need for a permanent black water tank to be installed.
I have never installed one, or have I seen an actual installation. The install/instruction manual can be downloaded from http://www.thetford.com. I have two questions for Thetford: Will this toilet be ok in a shower compartment? Can a standard sewage hose be fitted for use instead of the holding tank if hook ups are available at the campground?
This configuration may be better for a smaller footprint. The bowl swivels in either direction!
Cliff & Vanessa
cuyeda
Postby cuyeda » Thu Oct 02, 2008 11:03 am
Just a follow up... In case anyone was interested. I emaild customer service on the questions I had. Here is the reply.'
Good Morning,
The cassette unit will work with a shower combination, however it cannot be fitted with a sewer hose instead of the holding tank.
Sincerely,
Darlene
Consumer Service
Thetford Corp/Norcold Inc
Cliff & Vanessa
cuyeda
Postby Lucky489 » Thu Oct 02, 2008 4:09 pm
That is the same style that is on tent trailers. When I had my tent trailer. The cassette wasn't bad at all easily removed. The water tank for flushing is small about 2 gallons. We never had to empty it on a weekend camping with 5 people, but just used for number 2.
Lucky489
