FRONT UTILITY BOX
Re: FRONT UTILITY BOX BECOMES REALITY
Postby Esteban » Wed Sep 11, 2013 11:16 am
Perhaps a propane tank bracket like one from Adventure Trailer would work. It might be attached to the front of your tongue box or to the front of the teardrop.
http://adventuretrailers.com/acckitchen.html scroll down the page to see:
AT's aluminum propane bracket, sized to fit a 10 lb. propane tank.
Compact and light weight.
(DOT 10 lb cylinder 17.4" H x 8.9" diameter)
10lb Propane Bracket is $124.00
Or one from Helmar that is more affordable. http://www.helmarparts.com/product_p/tb-3.htm
Another choice http://www.suremarineservice.com/001-749.aspx
Powder Coated Aluminum Rail Mount Assembly (Tank not Included) for 6# Aluminum Propane Tank. Comes with Rail Mount Hardware, Rubber Bumpers and Tank Clamp. Use to Store Extra 6# Propane Tanks. Will fit 7/8" to 1" Rails.
Another one from etrailer.com http://www.etrailer.com/Accessories-and-Parts/Stromberg-Carlson/2020-JR.html?feed=npn&gclid=CN6wtPrZ4LECFSI0QgodxiUAQg
Stromberg Carlson Accessories and Parts - 2020-JR
Securely transport propane with a gas rack from Stromberg Carlson. Affix to the wall of your trailer and use only in compliance with city ordinances (check your own). This gas rack holds a single, 20-lb gas bottle for use as needed.
Features:
Transports gasoline safely for use as needed
Holds (1) 20-lb bottle
Made in the USA
1-Year limited warranty
2020-JR Stromberg Carlson Single Bottle LP Gas Rack for 20 lb Bottle
Steve - SLO, CA
Esteban
Images: 15
Postby MontanaTeardrops » Wed Sep 11, 2013 7:57 pm
Thanks for the links, but since I already started my bracket I might as well finish it. I still have a lot of time to think about because I won't be finishing it until next year.
Last edited by MontanaTeardrops on Sun Sep 29, 2013 8:31 am, edited 1 time in total.
MontanaTeardrops
Postby mikeschn » Thu Sep 12, 2013 6:12 pm
That's a cute setup for a 5 pound bottle...
This is how I did it on one of mine...
Postby vaddisonme » Thu Sep 12, 2013 7:29 pm
I have my 2 1-gallon propane tanks in my diamond plate front box. Since propane if heavy air, I put the vent holes in the bottom of the box. (Actually, I had to put the holes in the bottom to mount the box on the stub of the tire mount that used to be there...). Anyway, it is still waterproof, except for rain spray that may get kicked up if we are travelling in the rain. I like the propane tanks out of sight; those little refillable tanks are EXPENSIVE! :frightened: I dn't want anyone walking off with them.
The Marshmallow pulling our Sweet Potato.
vaddisonme
Postby KCStudly » Thu Sep 12, 2013 8:07 pm
The best schemes that I have seen have a method of locking the bottle to the trailer, usually thru an existing hole in the bottom ring.
Wish I could remember who's build had this detail.
Postby MontanaTeardrops » Thu Sep 12, 2013 11:12 pm
Thanks guys, good ideas all around. Would be nice to be able to keep the bottles safe because the darn little bottles are pretty spendy. I'm still impressed with all the talent on here. I'm glad I found this site, now my finished Teardrop is within sight next year when I can work on it again.
MontanaTeardrops
