Stabilizer Jacks
Postby synaps3 » Thu Mar 18, 2010 12:11 pm
Finn mentioned stabilizers like these earlier in the thread...
They're only $15 here:
http://www.etrailer.com/Trailer-Jack/Domar/TJ01RT.html
-- Dave
Build log: here
synaps3
Images: 254
Postby Classic Finn » Thu Mar 18, 2010 12:24 pm
synaps3 wrote:Finn mentioned stabilizers like these earlier in the thread...
Gees only 15 USD and 70 or 78 Euro here. :? :? :shock: :shock:
Classic Finn
Midnight Sun Voyager
Images: 146
Postby H-Balm » Wed Mar 24, 2010 4:49 pm
dreadcptflint wrote:We have two on our back end. My wife feels that they make a big difference. And anything that makes the wife feel better, makes me feel better. 8)
That is a wise statement.
H-Balm
Postby LDK » Wed Mar 24, 2010 8:25 pm
I'm gonna try something different I'm gonna make mine out of pvc pipe. 2in dia. and 1-1/2in dia. pvc . I'll make it where the 2in. tube screws into the bottom of the deck and the 1-1/2in tube will slide into the bigger tube. I'll have holes drilled in each tube to run a bolt through. If that doesn't get it level enough, all you have to do is unscrew the big tube alittle until it's perfectly level. I was brain storming the other nite and came up with this idea. I've done bought the pvc (under $20), and as soon as I get done with my trailer frame, I'm gonna install it. Larry
LDK
Postby synaps3 » Thu Mar 25, 2010 8:51 am
Larry -- PVC doesn't hold weight well. Your stands are going to collapse... It's a bad idea...
-- Dave
Build log: here
synaps3
Images: 254
Postby stomperxj » Thu Mar 25, 2010 9:20 am
I put 2 BAL 36" stab jacks on the back of mine...
stomperxj
Postby LDK » Thu Mar 25, 2010 5:40 pm
Dave, you may very well be right but I'm gonna give it a try anyway. I'm building it to stabilize not to hold weight. The tongue jack and the wheels do all the weight holding. What the heck if it fails, it fails, I only spent $17 on it. If it works I'll post pics.---- Larry------------------------------------------------------If it does break, I may use threaded metal pipes depending on how much trouble it is to find it or just use regular stabilizer jacks.---------Larry
LDK
Postby bohemian » Thu Mar 25, 2010 7:23 pm
Go for it Larry.I love that can/will do spirit. - Wayne :thumbsup:
bohemian
Images: 233
Postby CAJUN LADY » Thu Sep 16, 2010 11:25 am
I have had no luck with scissor jacks under my Teardrop or my Scotty. I don't know if they are just cheap made or what but right now one of them under the Scotty is being held up with a zip tie. It took forever to get that POS snapped back together. I'll take a pic and post it tomorrow.
I brought a pair of jacks I already had to use this last camping trip. They are heavy but they worked just fine.
I like the ones Finn posted. I had those on an old camper and they worked great.
Becca
~Cajun Lady~
CAJUN LADY
Images: 74
Postby Vindi_andy » Fri Sep 17, 2010 9:42 am
Larry your idea sounds like the sort of thing that go under kitchen cabinets
http://www.screwmaster.co.uk/plinth-fee ... s-35-p.asp
Boys never grow in to men the toys just get more expensive and more dangerous
How true :)
Vindi_andy
Images: 49
Postby fm-usa » Fri Sep 17, 2010 10:06 am
LARRY:
You might have a chance if you can minimize PVC from side movement.
Add another smaller leg off to the side, that'll create a triangle. If PVC can be kept from bending, it'll support a lot of weight.
(Crude pix)
PIPE ( N ) support ( / )
________________
N. . . . ./
N . . . /
N . . /
N . /
N /
N
N
N
N
OR both sides.
________________
\ . . N. . . . . . /
.\ . .N . . . . . /
. \ . N . . . . ./
. .\ .N . . . ./
. . . N . . . /
. . . N . . /
. . . N . /
. . . N /
. . . N
. . . N
. . . N
Is it possible, FULL RV in a 48 Sq.Ft. footprint & stay under 500Lbs wet?
SHE thinks teardrops are "cute" but I prefer a SKOSH mo-room & at 65+ the
body doesn't react/extract/move/mend/bend/lend or work like it use'ta.
NOW! Those unwanted guests moving in, Mr. 'Arther I. Tus' & Ms. DVT (grrr)
fm-usa
Location: ILLinois_60085 ================= Floyd_&_Debbie_+_Bailey
Postby LDK » Fri Sep 17, 2010 5:10 pm
This is an old thread. I changed my mind on the PVC stabilizer thing. I think it could work though but it would probably look tacky. I'll find some other way to stabilize my trailer. 8)
LDK
Postby George Taylor » Fri Sep 17, 2010 8:37 pm
We have 4 on ours. One at each corner. Check out these.
Bal 23025 Stabilizing Jacks Tent Trailer
George Taylor
Postby Hikerjohnd » Fri Sep 17, 2010 10:27 pm
Every camper I've used had two on the back corners & I thought they were great. I did see one guy at a campground whip out a drill with a socket on it & use that to raise & lower the jacks. Definitely something I will consider as my little li-on drill is usually in my truck!
--John
So be it.
Hikerjohnd
Images: 88
Postby halfdome, Danny » Sat Sep 18, 2010 11:28 am
Heikki, I put stabilizer jacks on the two rear corners of my builds because people expect them. I've attempted to use them but found them to be temperamental for leveling.
I use a scissor jack that's stored in the tongue box and a portable drill to drive it up and down for behind the wheel leveling. It's fast and easy, couldn't be happier. :D Danny
halfdome, Danny
*Happy Camper
Images: 252
