Kit Tear Question
Kit Tear Question
Postby Classic Finn » Sat Nov 10, 2007 4:45 am
Can anyone tell me the correct dimensions of the Original Kit and possibly the weight?
Id also like to know the proper height if possible..
Guess Ive got Kit Fever.. :D :)
Classic Finn :thumbsup:
Classic Finn
Midnight Sun Voyager
Images: 146
Postby Podunkfla » Sat Nov 10, 2007 5:10 am
Heikki... Prolly Andrew's "Trailer for Two" plan from the 1947 Popular Mechanics is pretty darn close to the Original Kit profile... except for the bottom curve in the front the Kit doesn't have. They were both designed to be cut out of a 4 x 8' sheet of plywood. Yeah, I wouldn't mind having a good set of "Kit Plans" too :thumbsup: ?
<B>~ Brick
Image...Lots more pix here!
Podunkfla
ol' noodle haid
Images: 5
Postby Gage » Sat Nov 10, 2007 5:15 am
Finn, check with Grant. He can also do you a templete of the profile. Which also will show cabinets and door location.
You know that one that is built back east somewhere is a pretty close klone.
Also George at the teardrop Fix-it-Shop makes a kit that when assembled looks like the real thing. Here's a quote from George's site.
"Teardrop Fix-It-Shop reproduces exact replicas of Kit and Kenskill Teardrop Trailers. These trailers are available as a pre-cut do-it-yourself kits or can be built to order."
His URL is:
http://www.teardropparts.com/index.htm
Image Image Image
Gage
Images: 28
Postby Classic Finn » Sat Nov 10, 2007 6:14 am
Gage wrote:Finn, check with Grant. He can also do you a templete of the profile. Which also will show cabinets and door location.
His URL is:
Hi Gage and Brick
I guess I should of worded it a little different.. my apologies.. I do have a nice template from Grant.. but I guess Im looking for the width and height when its on the frame...
Do the walls sit on top of the frame or hang on to the sides.. I just want to make sure I have this cut to proper measurements..
Im going to have Grants drawings done onto a computer here this coming week so then it can be cut on the Cnc.. And Id like some info as to what the parts of the hatch look like..The programmer told me to find out if I possibly can..
Yes Gage as you say I have the drawing also where it shows the places of the cabinets.. 8) 8) ;)
This is going to look real nice. :)
Heikki ;)
PS here are photos of Grants drawing... I just want to get the floor situated correctly and the sides on the way they are supposed to be..
http://tnttt.com/viewto ... ht=#271805
I have found 122cm or 4 foot wide aluminum in Mirror Polished or normal aslo.
and then I dont have the drawings of the hatch but maybe thats not so important? How thats actually built :thinking:
Classic Finn
Images: 146
Postby Classic Finn » Sun Nov 11, 2007 9:34 am
How does one start the floor on a Kit Build and from what material ? Or Is it only ply?
Classic Finn :thinking:
Classic Finn
Images: 146
Postby grant whipp » Tue Nov 13, 2007 1:05 pm
Hey, Heikki!
On the original KITs, the walls hung down past the floor about 2" to cover the frame rails (this is shown on the drawing I sent you ... ;) ...!). Since the overall width of the body was 4' and the walls were 1/2" plywood, that would make the plywood floor 47" wide. I'm pretty sure I did, but I think I sent you a sheet that showed a better way to do this ... :thinking: ...?
Also, the original KITs sat pretty low, maybe less than 12" ground clearance at the frame, so overall height was less than 5'. Rounding out the fender widths to 9" (remember, neither side were the same width, and neither were 9") will give you an overall width of about 66".
I can't say for certain about the Galley Lid framing without going to look, myself, but I do know it was open (not boxed). My preference would be to have your side ribs connected by four cross-beams and then boxed, but if you are going for the truely vintage KIT repro look, then have a look at some pics of the open galleys of an original or restored original.
This is just my opinion, but the original KITs had some design flaws and shortfalls ... if I were to build a modern-day version but still stay true to the overall KIT design, then I'd certainly try to address the flaws & shortfalls on the new build. Staying faithful to the KIT lore doesn't necessarilly mean you need to reprise their mistakes ...
Good Luck, my Friend, and as always ...
CHEERS!
Grant
grant whipp
Teardrop Manufacturer
Images: 117
Postby Classic Finn » Tue Nov 13, 2007 1:41 pm
Hey Grant
Thank You my friend, this info helps a lot..I,ll look at the drawing again to double check.. ;) :thumbsup:
Dear Grant could you get me a pic of the hatch you have when you get a chance? I reckon I,ll need to order a hinge for it then as well.. ;)
Classic Finn ;)
Ahh yes.. You will see a Kit in Finland Yet.. Determination says so. :lol: :lol:
Classic Finn
Images: 146
Users browsing this forum: Google [Bot] and 7 guests
