Cut another door
Cut another door
Postby fireaunt » Sat Jul 19, 2008 11:13 pm
Those of you with masterpiece TD are think nooo way. But mine is a folk art TD and only has one door. I don't know how it was built. If I cut a second door and put in braces would the TD still have enough strength to not collapse? There is a window there already.
Marilyn
fireaunt
Images: 38
Postby 2bits » Sat Jul 19, 2008 11:38 pm
I would think it would be just fine. It looks like your walls are solid, and not framed so if so, that would be fine for strength, and there wouldn't be any worries of hitting any wires either.
Thomas
2bits
2bit Member
Postby fireaunt » Sun Jul 20, 2008 12:02 am
Yep, there are certainly no wires. When I cut the shelf on the inside I found he had screwed and contact cemented the support in place. That's why I just cut out the part I didn't want and added another support.
I think cutting a door then adding vertical supports left and right and across the top might be ok. Are there instructions here for building a door.
Am I dreaming to think I could carefully cut out the side for the door and add a frame around it to be the new door?
Marilyn
Ignorance is bliss
fireaunt
Images: 38
Postby TPMcGinty » Sun Jul 20, 2008 1:04 am
fireaunt wrote:Yep, there are certainly no wires. When I cut the shelf on the inside I found he had screwed and contact cemented the support in place. That's why I just cut out the part I didn't want and added another support.
Marilyn
Ignorance is bliss
If your walls are 3/4 inch plywood then look in the Generic Benroy Plans on how to make a door.
Tim
TPMcGinty
Images: 146
Postby john » Sun Jul 20, 2008 1:05 am
I looks like you even have a matching window for the second door. :thumbsup:
Build I -- Scenic ---
http://www.flickr.com/photos/8121727@N04/
Goto the Tear Build file
Build II -- Scenic II ---
viewtopic.php?t=29603
Build III -- Scenic Solo---
viewtopic.php?f=50&t=50324
Travel Blog----Now without Political Commentary
http://polifrogblog.blogspot.com/2009/0 ... -2009.html
The Constitution was ratified, not an interpretation thereof...
Penomeli ikibobo
john
john
Images: 261
