[url="http://www.hunt101.com/?p=297811&c=500&z=1"]
[url="http://www.hunt101.com/?p=297810&c=500&z=1"]
At some point, if anyone is interested, I'll post what I"ve learned in constructing and mounting these curved
Next TD
Michael W wrote:Your door looks good. Keep up the good work.
Our teardrop also has two sides:
My side: First try-learn what not to do.
Her Side: Apply lessons learned.
McTeardrops wrote:Geron-What did you use for trim on inside of doors?
j_b317 wrote:I'm trying to get my doors mounted now in order to leave for Minden on Tuesday and I'm in a bind!
I've got the T moulding, and the edge moulding to go on the doors and in the cut outs respectively, but I'm not sure where to go with it. I cut the additional 1/8" off the bottom and the hinge side of the doors, but there's still not nearly enough room for the door frame edge moulding and the T moulding to fit in that slot. I want to be sure I'm going in the right direction before I lop more off the doors.
Any suggestions?![]()
jb
bdosborn wrote:Cool doors. I feel your pain on the trim, I'm not very hapy with mine. Better hurry up though, Minden is next weekend!
IraRat wrote:Geron--when you do the other one, PLEASE take a gazillion photos, like you're presenting a "How To."
Those doors are scaring the living crap out of me, and although I'll most probably go the traditional route (what other choices do we have?), my mind has been racing trying to come up with some new, innovative solution that no one's thought of yet.
But I guess you can't reinvent the wheel.
gman wrote:Did you try useing a tourch to heat the Aluminum in the Radius as you bent it? Small propane like used for plumbing is easy to control with one hand as you press with other. Wear heavy leather gloves, Al will tranfer heat far and fast.
