tape stains etc on aluminum...
Postby hammer & tongs » Tue Jul 19, 2005 8:02 am
I just want to clean some stains from my aluminum don't want to polish.
What have you folks used successfully ?
" By whose stripes you were healed ."
(1 Peter 2:24b )
hammer & tongs
Images: 9
Postby Endo » Tue Jul 19, 2005 12:24 pm
Hammer & tongs
I just tried a product made by De-Solv-It. It's called: Contractors' Solvent. It is designed for hard surfaces including cured paint, metal and wood. It is guranteed to remove: latex adhesin, oil, tar, grease, glue, foam, caulk, silicone, wet paint, and many other things.
I used it to remove the excess cualk around my trim and well as some other unknown black stuff on my aluminum. I sprayed it on a rag and wiped the stains away. I followed it up with alittle soap and water and a dry towel to remove any remaining solvent.
It worked great!
I bought the product at ACE Hardware.
Endo
Brad (aka Endo)
ImageImage Image
In God We Trust
Endo
Images: 138
Postby Brad Lustig » Tue Jul 19, 2005 12:39 pm
You may want to try WD-40. It's actually a much better solvent than lubricant or rust penetrator. I'd test it on some scrap aluminum, though
Brad Lustig
Postby hammer & tongs » Tue Jul 19, 2005 5:25 pm
Thanks guys;
I have some WD-40 on hand and will try it...if it doesn't do the trick, I can see a trip to ACE in my near future.
(1 Peter 2:24b )
hammer & tongs
Images: 9
Postby norm perkiss » Tue Jul 19, 2005 7:01 pm
You might try an auto paint supplier. They sell several kinds of cleaner/degreasers for prepping before painting. I used some a couple of years ago and it worked great, don't remember the brand. I used some laquer thinner on some tape residue the other day, came right off.
my 2ยข
Norm
norm perkiss
Images: 62
Postby Scooter » Tue Jul 19, 2005 8:18 pm
Mineral spirits (paint thinner) is worth a try. Works great on anything oil-based and softens tape residue too. $1.99 from Walmart. Can't beat it for lotsa general stuff.
The RoadCamper the old teardrop
Scooter
Images: 69
Postby ceebe » Tue Jul 19, 2005 11:06 pm
Used with care, gloves and a lot of ventilation, if none of the other suggestions work, MEK will ! :D
ceebe
Postby bledsoe3 » Wed Jul 20, 2005 12:00 am
There is a product called "Goof Off". Our builder gave us some to remove the stickers off the toilets. Worked good. You can see it here
http://www.valspar.com/val/resident/goof-off.jsp
bledsoe3
Images: 112
Postby Chris C » Wed Jul 20, 2005 7:45 am
I've used Goof Off for years................great stuff!
Chris :D
Chris C
Postby Cutterpup » Wed Jul 20, 2005 8:07 am
Try WD-40
Dan
Cutterpup
Images: 15
