gas struts
gas struts
Postby cpowell243 » Thu Jul 18, 2013 6:52 pm
Has anyone had luck using struts for a galley hatch that were robbed from a van or hathchback at a boneyard?
TH - CP
cpowell243
Images: 184
Re: gas struts
Postby absolutsnwbrdr » Fri Jul 19, 2013 8:49 am
I used the struts from a Subaru Forester on my first build. They worked ok, but it wasn't perfect.
New gas struts are actually pretty cheap, and then you know exactly what you're getting.
http://www.mcmaster.com/#gas-springs/=notnbz
While you're at it, here's two good threads about struts...
viewtopic.php?p=350386#p350386
viewtopic.php?p=54750#p54750
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Re: gas struts
Postby planovet » Fri Jul 19, 2013 9:08 am
I would go with new also, but that is just me.
ImageMark (& Cindi)
planovet
The Cat Man
Re: gas struts
Postby celticquetzel » Sat Jul 20, 2013 12:13 am
I've had to replace the ones on my 2000 Durango twice. Once they start to fail you may not notice until its gets cold - usually at a really inopportune time - then they are impossible. Not real expensive parts so definitely not worth using used. Just my experience.
celticquetzel
Re: gas struts
Postby mikeschn » Sat Jul 20, 2013 5:58 am
I bought mine at Mcmaster.com They are very affordable... like $15 to $20 or so...
