If you built your doors from scratch....
What hinges did you use
Did you use the same door as you cut out. and if you did how did put it back in and insolate it??
and how did you insolate it
RonD.
toypusher wrote:I used the section from the walls that I cut out to build the doors. I cut the 'cutouts down to 1/4" smaller all the way around. The doors were then build exactly like the sidewalls (3/8" plywood outside - 3/4" 1xs framing - 3/4" insulation - 1/8" plywood inside - and aluminum outer skin. Some deadsoft t-moulding, AL trim around the edges and a SS piano hinge to hang it.
