If you built your doors from scatch ...
Postby Ron Dickey » Sun Mar 19, 2006 2:51 pm
If you built your doors from scratch....
What hinges did you use
Did you use the same door as you cut out. and if you did how did put it back in and insolate it??
and how did you insolate it
RonD.
173882......173887
Ron Dickey
Images: 787
Postby toypusher » Sun Mar 19, 2006 3:43 pm
I used the section from the walls that I cut out to build the doors. I cut the 'cutouts down to 1/4" smaller all the way around. The doors were then build exactly like the sidewalls (3/8" plywood outside - 3/4" 1xs framing - 3/4" insulation - 1/8" plywood inside - and aluminum outer skin. Some deadsoft t-moulding, AL trim around the edges and a SS piano hinge to hang it.
toypusher
Images: 324
Postby WarPony » Sun Mar 19, 2006 3:50 pm
I built my door from scratch. I had to build a second one after I cut the window opening wrong. I probably overbuilt it but I figured with all the opening and shutting, a lightweight one would probably fall apart over time. I used a piano hinge to hang it and didn't have alot of insulation because of the amount of wood used in the construction. I've probably got over 2,000 miles on it since last June and haven't had any problems at all.
WarPony
Images: 289
Postby bdosborn » Sun Mar 19, 2006 4:24 pm
toypusher wrote:I used the section from the walls that I cut out to build the doors. I cut the 'cutouts down to 1/4" smaller all the way around. The doors were then build exactly like the sidewalls (3/8" plywood outside - 3/4" 1xs framing - 3/4" insulation - 1/8" plywood inside - and aluminum outer skin. Some deadsoft t-moulding, AL trim around the edges and a SS piano hinge to hang it.
I did the same thing.
Images: 806
Postby Ira » Sun Mar 19, 2006 5:14 pm
I did the same as Bruce--only mine didn't come out as nice.
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby Hardin Valley Magic » Sun Mar 19, 2006 7:22 pm
I built the wall with the framing in it to be cut out and used for the door. I done it to keep the grooves in the wood the same and line up accordingly once the piano hinge was installed. I used beaded board inside and out and almost installed them backwards because the grooves were very close to matching.
aka Steven D.
Hardin Valley Magic
Postby Ron Dickey » Tue Mar 21, 2006 2:40 pm
should I frame it then cut it or cut then frame it. and then add insolation on edges.
:thinking:
RonD.
173882......173887
Ron Dickey
Images: 787
Postby WarPony » Tue Mar 21, 2006 7:55 pm
Ron, I cut out the door, laid it on the floor and built the frame on top of it. I didn't make the frame dead nuts accurate because I knew I would have to trim some to make the door gap right. When I got the frame done, I put insulation in the spaces then put the interior skin on. It worked pretty good for me.
WarPony
Images: 289
