Washing Machine Woes
Postby doug hodder » Sun Sep 02, 2007 10:28 am
Ira...you mentioned that it had spark...check the fuel lines!....Doug
Postby Ira » Sun Sep 02, 2007 10:36 am
The aggravating thing about this is that I don't want to go today for this, I sure don't want to go tomorrow, so that means after work.
That cuts into my bar time, which is never a good thing.
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby Juneaudave » Sun Sep 02, 2007 10:44 am
Ira wrote:The aggravating thing about this is that I don't want to go today for this, I sure don't want to go tomorrow, so that means after work.
I always thought the sum of "laundry room" plus "working on a washing machine" equalled "six pack"
:lol: :lol: :lol:
Did you bash that solenoid do thingy with a stick? If that doesn't work for me, then I get out of the way and let Marcia fix it.
Juneaudave
Images: 380
Postby Q » Sun Sep 02, 2007 12:38 pm
Ira,
You never did say what brand of washer you have. I used to be an appliance repair man and might be able to help if you still want to fix it.
Q
Q
Postby Ira » Sun Sep 02, 2007 1:36 pm
It's a Maytag.
Too bad that the guy on those commercials died, or he wouldn't be the loneliest man in the world any more.
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby Q » Sun Sep 02, 2007 6:03 pm
Ira,
The old Maytags are good machines. New machines for the most part are much more complicated and lower quality. There is not much that can cause a slow fill other than a restriction in the control valve.
When I got called out on a slow fill problem, the first thing I would do is unscrew the hoses from the back of the washer, put the ends in a bucket, turn on the water and check for good flow. If that was OK I would pull the inlet screens out of the valve (with a dental tool) and make sure they were clear. If they were clear, labor being what it is, I'd just replace it the valve. You can however take the valve apart and clean it, and test it by putting 110V to the terminals on each coil.
Q
Q
Postby Kevin A » Sun Sep 02, 2007 7:21 pm
Ira, here's a few options for ya. ;)
Kevin A
The other guy
Images: 289
Postby Laredo » Sun Sep 02, 2007 8:21 pm
Ira,
I got a really good deal about 3 years ago at lowe's on a front-loading washer and a new dryer (the appliances these replaced were bought new in 1980, so I had in fact gotten my money's worth; but I replaced them because I could no longer get the correct heating element for the 1980 dryer or replace the control circuitry in the 1980 washer). Now, if you haven't bought your washer yet, see if Mrs. Ira will go for a front-loader. It cut our water bill by $30 a month (I have teenagers).
Laredo
Postby Elumia » Sun Sep 02, 2007 9:56 pm
Also check for rebates. When I bought my front loader recently becasue the old washer had leaked forever. I applied for:
$100 rebate from the water company
$35 rebate from Power company
$50 rebate from Mfg
$50 delivery rebate from Home depot (they took away the old one too, so no cost to dispose)
signed up for a credit card from home depot and got 1 year of free interest (just be sure to pay the bill off before the end of the year)
so the $799 washer cost a little more than a cheap top loader. in addition to the water savings, it also saves you on dryer costs as they spin at a higher rpm which gets more water out of the clothes so the dryer time is shorter.
Mark
Elumia
Images: 15
Postby john » Mon Sep 03, 2007 8:47 pm
When you removed the hoses did you check the strainers inside the things the hoses screw onto on the washer?
Build I -- Scenic ---
http://www.flickr.com/photos/8121727@N04/
Goto the Tear Build file
Build II -- Scenic II ---
viewtopic.php?t=29603
Build III -- Scenic Solo---
viewtopic.php?f=50&t=50324
Travel Blog----Now without Political Commentary
http://polifrogblog.blogspot.com/2009/0 ... -2009.html
The Constitution was ratified, not an interpretation thereof...
Penomeli ikibobo
john
john
Images: 261
Postby sdtripper2 » Mon Sep 03, 2007 9:53 pm
Yes John...
Think you have Ira's answer ....
Was just thinking of the same .... and see you got the question I was going :thumbsup:
to ask Ira.
Three typical problem areas with restricted flow.
The main turn ons are cut back
The strainer is plugged
The inlet valves are partially blocked or...
and most likely the strainer is the culprit.
Good luck Ira ~ 8)
As a person who has worked on washing machines I feel your pain.
However if John has your answer ... the pain will be short lived, now ~
sdtripper2
Search Garoux
Images: 168
Postby sdtripper2 » Sun Sep 09, 2007 10:21 pm
Ira...
What was the fix for your washing machineImage
sdtripper2
Search Garoux
Images: 168
Postby apratt » Sun Sep 09, 2007 10:38 pm
His credit card :rofl: :rofl: :rofl:
sorry couldn't help myself.
Arthur,
ASL spoken here
apratt
Images: 16
Postby sdtripper2 » Sun Sep 09, 2007 10:43 pm
Stick out yur hand ~ Arthur
:D
sdtripper2
Search Garoux
Images: 168
