Dead Battery
Dead Battery
Postby Christina » Tue Jun 01, 2010 1:02 pm
Hello. I think I need to replace my TD's battery (it died over the winter :cry: ). It is a Transcontinental sealed rechargeable valve regulated lead acid battery. It runs just the lights, a few 12-volt plugs and a small fan. Should I look for the same kind, or does anyone have a battery that they just love? Any other recommendations? There is a charger included with the battery, but it seems to take a very long time to charge up the battery (over 8 hours).
Christina
Images: 5
Postby TPMcGinty » Tue Jun 01, 2010 2:33 pm
Any deep cycle battery should work fine for what you power off of it.
Tim
TPMcGinty
Images: 146
Postby Christina » Tue Jun 08, 2010 6:24 pm
Thanks! The Sunflower is good to go. :D
Christina
Images: 5
Postby Ageless » Tue Jun 08, 2010 7:52 pm
btw; deep cycle batteries charge slowly. I put the 6 amp charger on mine and it never draws more than 3.
Ageless
Postby wannabefree » Tue Jun 08, 2010 9:00 pm
8 hours is not slow for charging a VRLA type battery; 13 hours or so is normal for a depleted battery. The simple thing is to get a battery with about the same AH rating. Your battery ampacity should be about 10x your charger's charge rate for optimal battery charging. So if the charger is rated 3A, you should have about a 30AH battery. This is all loosy-goosy and +/-20% is no big deal. What you want to avoid is a big mismatch between charger and battery, like a 10A charger on a 20AH battery.
In anything at all, perfection is finally attained not when there is no longer anything to add, but when there is no longer anything to take away.
-- Antoine de Saint-Exupery
wannabefree
Images: 82
Battery Tutorial
Postby Engineer Guy » Tue Jun 08, 2010 9:19 pm
I had this Site bookmarked. I hope it helps a bit...
http://www.batterystuff.com/tutorial_battery.html
Engineer Guy
Images: 118
car and deep 12v
Postby kjmckay » Sun Jun 13, 2010 9:43 am
I did this on two car and my deep 12 volt and it worked
http://www.ehow.com/how_4853344_recondi ... ttery.html
Life is just Great, work- camp- fish- and Angels Baseball
kjmckay
Images: 39
Postby Dale M. » Sun Jun 13, 2010 1:08 pm
Here is another good battery information site...
http://www.batteryfaq.org/
Dale
Dale M.
Images: 18
Postby Shadow Catcher » Sun Jun 13, 2010 2:59 pm
Having looked at a lot of information I prefer the Lifeline AGM www.lifelinebatteries.com mostly because of the lack of need for attention/stores well
