Getting Started!
Getting Started!
Postby cablerunners » Fri Oct 06, 2006 3:07 pm
Hi All,
I got my steel and axle! I plan to start welding it all up this weekend. :)
I'm renting an ARC welder and going to stick weld it.
-phil
cablerunners
Images: 125
Postby sdtripper2 » Fri Oct 06, 2006 5:42 pm
Phil: :)
This picture of your axle shows exactly what MadJack talks about when he
says the following information that I have put on the trailer start page sticky:
On Sticky @ top of this forum wrote:If you are installing your axle please read this from Jack (MadJack):
"IF, you have a perfectly straight axle, you can just flip it over...however
most axles have just the slightest of bows and that bow ABSOLUTELY has
to point upwards...if you flip it over it will point downwards...do not rely on
your eyes alone...take a straight edge and lay it on the axle to see if it has
a bow in it"
See the slight bowed axle here, so you know what you are looking for.
Thank you Phil for sharing your picture with us. :)
sdtripper2
Search Garoux
Images: 168
Postby mikeschn » Fri Oct 06, 2006 6:36 pm
Phil,
Is that a heater I see in your garage? Does it spit out reams of CO? (Carbon Monoxide!) You weren't planning on heating your teardrop with that were you?
Nice picture of the chassis setup waiting for the welder. But why stick? Isn't mig easier?
Postby cablerunners » Fri Oct 06, 2006 7:09 pm
Hey,
Steve... Funny I did not notice the bow in the axle till you mentioned it... The axle and framing are in an upside down state... so the bow will be upward. Thanks!
Mike... that green heater is on it's way to Goodwill. I had held onto it to see if my son-in-law wanted it but no.
To all.. what Mike brought up is a very important safety matter, please select your heaters carefully! That one in the foreground (green guy) is for outdoors use only. Sorry it slipped into the photo, but it's on the way out of the garage.
-phil
cablerunners
Images: 125
Postby cablerunners » Sat Oct 07, 2006 8:48 pm
Well, after a long day... I got the frame welded up!!!
Man am I tired!!!
I put some pics in my album, for you all to check out. :)
-phil
cablerunners
Images: 125
Postby bledsoe3 » Sun Oct 08, 2006 10:17 am
You don't mess around when you say you're goin' to do something! It was nice to meet you and your wife. Let me know if you have any more questions.
bledsoe3
Images: 112
Postby cablerunners » Mon Oct 09, 2006 7:57 am
LOL,
Thanks Bledsoe3... It was a pleasure to meet you too, and you answered many, many questions I had about building a TD.
I found a set of wheels and tires Sunday, but I don't have them on yet. I'll post a pic soon as I do.
-phil
cablerunners
Images: 125
Postby CHUCKLEHEAD69 » Tue Oct 10, 2006 7:03 pm
looked at your pics looks good. any reason u ran the channel like that (facing out) or was it personal preference just curious too about all the half used rods on the ground in frame10 pic. it looks very strong and should make a great tear. :thumbsup:
JUDE ------- "Laissez les bons temps rouler. let the good times roll"
CHUCKLEHEAD69
Images: 58
Postby cablerunners » Tue Oct 10, 2006 8:00 pm
Sup Chucklehead69!
Thanks, I think I'm building a tank... :lol:
I ran the Channel on the outside, cause I'm planning to rip 2x3s down to fit inside the channel to mount the side walls to. The plywood deck is mounting right on the metal frame... (no wood under the plywood).
As for the half used rods... :oops:
I got the wheels on today, but I still have a bit of welding to do.
More pictures this weekend. :thumbsup:
-phil
cablerunners
Images: 125
Postby CHUCKLEHEAD69 » Tue Oct 10, 2006 8:14 pm
ok sounds good.now i understand :thumbsup:
CHUCKLEHEAD69
Images: 58
Postby Micro469 » Tue Oct 10, 2006 9:35 pm
cablerunners wrote:Sup Chucklehead69!
-phil
Now that is a great idea... :thumbsup:
John
Micro469
Images: 382
