I got my steel and axle! I plan to start welding it all up this weekend.
I'm renting an ARC welder and going to stick weld it.
-phil
On Sticky @ top of this forum wrote:If you are installing your axle please read this from Jack (MadJack):
"IF, you have a perfectly straight axle, you can just flip it over...however
most axles have just the slightest of bows and that bow ABSOLUTELY has
to point upwards...if you flip it over it will point downwards...do not rely on
your eyes alone...take a straight edge and lay it on the axle to see if it has
a bow in it"See the slight bowed axle here, so you know what you are looking for.
cablerunners wrote:Sup Chucklehead69!
Thanks, I think I'm building a tank...![]()
I ran the Channel on the outside, cause I'm planning to rip 2x3s down to fit inside the channel to mount the side walls to. The plywood deck is mounting right on the metal frame... (no wood under the plywood).
-phil
