Need help with A-Frame tongue math
Postby dh » Wed Sep 02, 2009 9:36 pm
OK, I havent used geometry since I took a class back in '97
So, my trailer is X" wide, the A frame tongue members are at a 55 deg angle (Isn't that industry standard?) How long will the individual tongue members be, and how long will the tongue, be?
dh
Postby doug hodder » Wed Sep 02, 2009 10:02 pm
You don't have to use the stamped 55 degree coupler, unless you have already purchased it. I decide on a tongue length, then run the A members back under the trailer past the front cross member into the side rails. I attach them just aft of the coupler, a straight one. I find that it gives me a longer tongue which makes it easier for loading the truck, and I don't get into the trailer front when backing and it's somewhat easier to back, as it's not so "fast" on the turning. I think that the 55 degree coupler works better on a wider trailer, but with the widths that these have, it causes your tongue to be shorter if you want the A members under the front for support. Doug
Trying to figure out my options
Postby dh » Thu Sep 03, 2009 6:33 pm
I'm just trying to figure out what it would be though. I like to plan everythng to death and explore every option before I build.
I remember there is a way to figure length without having to lay everything up, but I haven't done it since high school.
I can hear Mrs. Coldwell now, "I told you that you would need to know this..."
dh
Postby mikeschn » Thu Sep 03, 2009 6:43 pm
Here's a tongue length sketch I did about 5 years ago...
the tongue angle is 50 degrees btw.!
http://tnttt.com/viewto ... ongue#1942
Thanks
Postby dh » Thu Sep 03, 2009 9:41 pm
Thanks Mike, I appriciate it :applause: :applause: :applause:
dh
Thanks
Postby dh » Fri Sep 04, 2009 12:34 am
dh
